Re: centreline between 2 polylines
barry2104
barry2104
how silly of me... thanks.
I also found the VLX Lisp for "CURVEAXIS" online, which Looks to do the same as the Lisp from this Forum, but has the added Option of outputting as a spline or 3d polyline
is it possible to somehow convert a vlx to a .lsp file? It'd be nice to have all the same file types in my Lisp folder
Running AutoCAD Architecture 2020, in German
barry2104
so the Output looked good at first glance, but upon closer inspection it's obvious that this doesn't work accurately (at least not for my curved Situation)
Here the red line (Output) doesn't cross through the midpoint of the selected line, and for the curved part of the Output, lies obviously Closer to the top black curve. Why is this?
j.palmeL29YX
@barry2104 wrote:
... upon closer inspection it's obvious that this doesn't work accurately
Why not? Why did you draw the selected line in the position which is shown in your pic? How is the position of your line determined? My attached pic shows as example three other lines, whose midpoint is placed at the "centerline" and the endpoints touch the two borderlines.
In other forums we have discussed this issue (create a middle curve between two given curves) very often - without a finally result. The main problem (IMHO): nowone can describe exactly, what is the middle between two curves.
Jürgen
Jürgen Palme
Kent1Cooper
@j.palmeL29YX wrote:
.... we have discussed this issue (create a middle curve between two given curves) very often - without a finally result. The main problem (IMHO): nowone can describe exactly, what is the middle between two curves.
For some discussion of that issue, see >this< and following Messages on that same thread, especially the link at the end of Message 44.
Kent Cooper, AIA
j.palmeL29YX
Thx to @Kent1Cooper  for the link.
Here still another way to get a centerline between two given curves (2D).
In many (not all) cases we get an acceptable solution.
(I didn't a close check if this way was already shown in one of the previous postings).
Jürgen Palme
Sea-Haven
Nice solution as you can control the number of facets. There is another post floating around about curve fitting to a pline with a 1000 points. Maybe copy parallel, do mesh and find middle,  play with resolution of grids.
http://www.theswamp.org/index.php?topic=55530.0
gpcattaneo
Similar method here
Almost 🙂
