R2019: vla-getremotefile fails
kenkrupa
kenkrupa
Automation Error. File access error.
This code still works fine in R2018 and older:
(defun kcs_get_remote_text (/ fname objDOC objUTL locfile)
  (vl-load-com)
  (setq fname "http://www.krupacadd.com/Kcs_AEC_version.txt")
  (setq objDOC (vla-get-activedocument (vlax-get-acad-object)))
  (setq objUTL (vla-get-utility objDOC))
  (vla-getremotefile
    objUTL
    fname
    'locfile
    :vlax-true
  ) ; error: Automation Error. File access error HERE
  locfile
  ; return should be something like:
  ; "C:\\Users\\Ken\\AppData\\Local\\Microsoft\\Windows\\Temporary Internet
  ; Files\\Content.IE5\\3QGF1PFV\\Kcs_AEC_version[1].txt"
Looks like this is a bug in 2019.  Autodesk - PLEASE FIX!
artc2
In 2019, getremotefile is controlled by the new SECUREREMOTEACCESS sysvar which defaults to 1 (disallowing getremotefile). Try setting SECUREREMOTEACCESS to 0.
kenkrupa
Thank you!
I have not been able to find a source for this info - can you point me to it?
cadffm
F1 Help
New Systemvariables (and some more infos about changes)
Or in the normal WhatsNew overwiew.
http://help.autodesk.com/view/ACD/2019/ENU/?guid=GUID-4B04BE19-E966-4EE1-A21D-D00540BFE635
Sebastian
kenkrupa
Oh - I see it's in F1 Help, if you look hard enough.
kenkrupa
Never found my way to that web page. Thank you.
