R10 LISP to 2002
R10 LISP to 2002
R10 LISP to 2002
I need to use LISP files created for Release 10 in Acad
2002.
What changes do I nee to make to the files? I noticed in
some examples that "Command" included "_." before the actual
command as in: (command "_.line" pt1 pt2 """").
Also where do I get 2002 to recognize the directory these
LISP files are in?
Thanks in advance,
Gale Gorman
Houston
Autocad wil recognize the files if you put the path in:
tool->options->files->support file search path.
There are several changes in lisp between 10 and 2002, one is the "_".
The best way is just trying.
jan
"Gale Gorman" schreef in bericht
news:A427F429ED4EE31DEACB8DF2363C81B7@in.WebX.maYIadrTaRb...
> 2002.
> LISP files are in?
> Thanks in advance,
> Gale Gorman
> Houston
I thought the "_" was only for working with different language versions.
"-" (hyphen) needed before "insert".
Not new but "." before command uses the actual AutoCAD command (".quit") not
a redefined version.
"Jan van de Poel" wrote in message
news:E0E662280B5B4516358141D01169ED01@in.WebX.maYIadrTaRb...
> jan
> > 2002.
> > LISP files are in?
> > Thanks in advance,
> > Gale Gorman
> > Houston
You're correct, that's why i wrote " one of the changes ".
Besides the "_" "-" and "." there are some small command changes.
Don't remember what more changes there are, some commands are a little
changed and many have been added.
Jan
"Warren Trost" schreef in bericht
news:FEF40A32A1EFFDE16DAAA1E41EBD4ADF@in.WebX.maYIadrTaRb...
not
> > jan
> > > 2002.
> > > LISP files are in?
> > > Thanks in advance,
> > > Gale Gorman
> > > Houston
If you have the AutoDesk Migration Tools installed, there is an AutoLISP
compatibility Analyzer that does a good job of flagging potential errors.
David
"Gale Gorman" wrote in message
> 2002.
> LISP files are in?
> Thanks in advance,
> Gale Gorman
> Houston
