"/" in menu
"/" in menu
Message 1 of 9
"/" in menu
I'm attempting to write a custom menu which
will open a particular drawing by selecting a menu
option. This requires a path to the directory in which
the drawing is located. The problem is that the / in the
path is interpreted as a pause for user input. Can anyone
help me?
Replies (8)
Message 2 of 9
Try using "\" instead. That should work. Ken.
John Bockleman wrote in message
news:7vt2bv$98u29@adesknews2.autodesk.com...
> help me?
> Thanks
Message 3 of 9
Are you sure you are not confusing / with \
\ pauses for user input while / is ok for file paths.
To avoid the file dialogue box use FILEOPEN
rather than OPEN.
or maybe you are using long filenames and/or paths
which should be enclosed in double quotes.
e.g.
[Open This One]^C^CFILEOPEN "C:/ACAD DWGS/THIS ONE.DWG"
As a side comment it is usually better to avoid having hard-coded
file names in your menu file. Better to refer to a global lisp variable,
or a users# variable, or a CFG variable,or a dictionary record,
which can be set in YOURMENU.MNU file and accessed via
a simple lisp function.
Regards Ian
John Bockleman wrote in message <7vt2bv$98u29@adesknews2.autodesk.com>...
>help me?
>Thanks
Message 4 of 9
Error in previous post.
YOURMENU.MNU file should read YOURMENU.MNL file.
Regards Ian
Ian Bryant wrote in message <7vuati$da53@adesknews2.autodesk.com>...
>rather than OPEN.
>e.g.
>Regards Ian
Message 5 of 9
if you really want to hard code a path you could use STRCAT and (CHR 92)
... I think that's the ascii number for "\" .... like so: (strcat "c:"
(chr 92) "filename.ext")
> help me?
> Thanks
Later,
Josh
joshc@mindspring.com
"I'm a perfectionist...I'm just not very good at it."
Message 6 of 9
Or, possibly a \\ would work well as it is equal to a / in most paths.
Dave D
(remove '-' for Email)
Josh wrote in article
<3828D91C.48C2EC11@mindspring.com>...
> > help me?
> > Thanks
> Later,
> Josh
Message 7 of 9
Autolisp interprets both \ and // as /, and / as pause.
>help me?
>Thanks
Message 8 of 9
The "\" (backslash) is interpreted as a in a menu macro. Replace the
"\" (Backslashes) with "/" (Forward Slashes) in the path and it should be
fine. (I think that's what you meant below.)
NOTE: A menu macro will not interpret "\\" as a single backslash like in
AutoLISP. It will just issue Two instructions.
Phillip Kenewell
CAD Systems Technician
Air Gage Company
pkenewell@airgage.com
> Not < a Member of the AutoDESK
Discussion Forum Moderator Program
> help me?
> Thanks
Message 9 of 9
Huh?
Then I must be using a 'special' version of AutoLISP.
(load "c:\\acad\\r14\\lmsfiles\\acad") and
(load "c:/acad/r14/lmsfiles/acad")
both work for me in a routine, and
even works in a menu.
I think John's problem is with the command "open" itself.
Dave D
Art Mahanna wrote in article
<80ccrd$cou31@adesknews2.autodesk.com>...
> >help me?
> >Thanks
