"NUKE" lisp?
"NUKE" lisp?
Netelaana
Message 1 of 26
"NUKE" lisp?
Netelaana
I have a CAD file with a couple layouts. I need to reduce the model & layouts content to its constituent parts without loosing visible information. Manually I go about it in this way:
1. select all
     -burst
          -repeat until no more items to burst
2. select all
     - explode (ideally blocks explode onto the blocks layer not "0")
3. repeat 1&2 until no more items to burst or explode.
4. repeat 1-3 for each layout
5. purge all
6. audit - fix errors
This seems an ideal job for a LISP that might aptly be named "NUKE"
Something along the lines of lee mac http://www.lee-mac.com/upgradedburst.html makes me think it should be possible.
As one can imagine, this process takes quite a bit of time. Any help would be greatly appreciated,
Thanks!
Replies (25)
Message 21 of 26
roland.r71
Ok.
Don't forget it requires Lee Mac's "Burst upgraded v1.7". Which you can find >here< along with a ton of other goodies 🙂
Message 22 of 26
roland.r71
I just tested it myself on a set of layouts containing circuit diagrams and it worked like a charm.
I just added some comments, an extra warning at the start and a "undo".
(defun c:NukeDWG ( / ltab bss fnd)
   ; Function to "nuke" a set of layouts down to nothing but poly's & text
   ; Note: This function requires Lee Mac's Burst Upgraded v1.7
   ;       as found at: http://lee-mac.com/upgradedburst.html
   ; USE WITH CAUTION !
   (setq cmdecho (getvar "cmdecho"))
   (setvar "cmdecho" 0)
   (command "_.UNDO" "_Begin")
   ; The process of bursting everything on each layout can take quite some time.
   ; ACAD might report as "not responding", while it is working in the background.
   (alert "WARNING: This dwg is about to get Nuked!\n\nnote: this process can take a while.")
   (foreach ltab (layoutlist)
      (setvar 'ctab ltab)
      (command "_zoom" "_a")
      (setq bss (ssget "X" (list (cons 0 "INSERT")(cons 410 ltab)))
      (princ"\n---------------------------------------")
      (if bss
         (progn
            (princ (strcat "\nBursting blocks on layout: " ltab))
            (LM:burstsel bss t)
            (setq fnd t)
            (command "_explode" "all")
         (princ (strcat "\nNo blocks found on layout: " ltab))
   (command "_purge" "all" "*" "N")
   (command "_OVERKILL" allobjects "" "Yes" "Yes")
   (command "_AUDIT")
   (if fnd
      (alert "This drawing got Nuked!")
      (alert "No blocks present in drawing!")
   (command "_.UNDO" "_End")
   (setvar "cmdecho" cmdecho)
   (princ)
Message 23 of 26
Netelaana
thanks! finally got a chance to try it. It sort of does the trick - polylines, mtext and a few attributes are left un-exploded in paperspace (due to nesting?), and model space does not seem to participate - all blocks are still intact.
Message 24 of 26
roland.r71
I didn't go as far as exploding each polylines, I think I know why the mtext didn't get exploded, wasn't sure if it was supposed too. & it currently only works on layouts, so yes, modelspace was left untouched. Which all can be arranged.
...but remaining attributes ? that's a wierd one.
edit:
Could you possibly share a sample drawing to test with?
Message 25 of 26
ronjonp
What is the purpose of this simplification? Does it get fed to a machine that cannot handle complex objects?
You might want to wrap your code in something like this so that all layers are unlocked and all blocks are made 'explodable'.
(defun c:foo (/ a d)
  (setq d (vla-get-activedocument (vlax-get-acad-object)))
  ;; Unlock all layers
  (vlax-for l (vla-get-layers d)
    (cond ((= -1 (vlax-get l 'lock)) (vlax-put l 'lock 0) (setq a (cons l a))))
  ;; Make all blocks explodable
  (vlax-for b (vla-get-blocks d)
    (and (= 0 (vlax-get b 'isxref) (vlax-get b 'islayout)) (vlax-put b 'explodable -1))
  ;; Your bustemupcode :)
  ;; Relock layers
  (foreach l a (vl-catch-all-apply 'vlax-put (list l 'lock -1)))
  (princ)
(vl-load-com)
Message 26 of 26
Netelaana
There are a couple of different factors that converge and create this need, almost all of them outside of my control - some for input into other program, some policy, some historical precedent from when everything was just basic line/stick drawings. If it would be possible to add a round or two of explode & burst on each layout and the model, that would be ideal.
Again, my current manual workflow looks like:
1. in model space, select all, burst, repeat until no more items to burst
2. select all, explode once (ideally blocks explode onto the blocks layer not "0")
3. repeat steps 1-2 until no more items to burst or explode.
4. repeat steps 1-3 (in paperspace) for each layout
5. purge all; overkill; audit
any help automating that workflow would be fantastic.
