"-INSERTCONTENT" not functioning as expected
mspeace
mspeace
I have an older LISP routine I'm trying to get working in my new company. I used to use the "-insert" command but that was not working.
we have a drawing called "General.dwg" that contains block definitions for basic sheet layout. Things like north arrow, title blocks, logos, match lines etc. I want to insert 2 of the block defined in that drawing. The full Path for the drawing containing the blocks is,
"C:\RICK_C3D\C3D_RICK_NCS_2022\Resources\DEN\DEN_GENERAL.dwg"
EN-ARRW_2_COLOR
and
ARV_RICK_Logo_EXHBIT
However, my LISP hangs at the end of each "-INSERTCONTENT". What am I missing?
When I run it I can manually hit enter and it continues to the next "-INSERTCONTENT" command, then I hit enter again, and it completes. Its also not rotate the north arrow block correctly. I'm clearly missing a parameter or variable expected by the "-INSERTCONTENT" command. I tried reading up on it but the documentation is lacking in my opinion. I would love some guidance.
paullimapa
the first command line seems to only require two returns at the end like this:
(command "-INSERTCONTENT" "C:\\Autodesk\\DEN_GENERAL.dwg" "DEN-ARRW_2_COLOR" (getvar "viewctr") "" "")
Paul Li
IT Specialist
@The Office
mspeace
ah yes, duh! I knew it was something silly. Now I just need to work out how to prevent the pop up about redefining the block.
paullimapa
@mspeace updated try this:
Note: BLOCKREDEFINEMODE variable with 2 settings was introduced in AutoCAD 2022
(if(tblsearch"BLOCK""DEN-ARRW_2_COLOR") ; chk if block exists
 (progn ; then do following
  (setq BLOCKREDEFINEMODE (getvar "BLOCKREDEFINEMODE"))
  (setvar "BLOCKREDEFINEMODE" 2)
  (command "-INSERTCONTENT" "C:\\Autodesk\\DEN_GENERAL.dwg" "DEN-ARRW_2_COLOR" "_Y" (getvar "viewctr") "" "")
  (setvar "BLOCKREDEFINEMODE" BLOCKREDEFINEMODE)
 ; else just insertcontent
Paul Li
IT Specialist
@The Office
mspeace
yeah I was considering a test for it. Thanks.
paullimapa
Looks like AutoCAD only prompts for redefinition if the inserted block actually changed. But if it did not then there would be no prompt. So unless you know for sure that the current inserted block is different, the extra "_Y" in there would cause the routine to fail.
Paul Li
IT Specialist
@The Office
