quickest route between 2 points
rpajounia
rpajounia
If i wanted to get from point 1 to point 2 and i wanted to only use the lines in the drawing how can i make a code that will get me from point 1 to point 2, for example go from x,y point to x,y point to x,y point to x,y point?
Code below works great for lines but how do i get it to work with polylines?
; Find the path of minimum total length between two given nodes g and f.      ;
; Using Dijkstra Algorithm                                                    ;
; See http://tech-algorithm.com/articles/dijkstra-algorithm/                  ;
; Written by ymg   August 2013                                                ;
(defun minpath ( g f nodes edges / brname clnodes closedl dst1 dst2 m minpath minpathn mp new nodname old oldpos openl totdist )
  (setq nodes   (vl-remove g nodes)
        openl   (list (list g 0 nil))
        closedl nil
  (foreach n nodes
    (setq nodes (subst (list n 0 nil) n nodes))
  (while (not (equal (caar closedl) f 1e-6))
    (setq nodname (caar openl)
          totdist (cadar openl)
          closedl (cons (car openl) closedl)
          openl   (cdr openl)
          clnodes (mapcar 'car closedl)
    (foreach e edges
      (setq brname nil)
      (if (equal (car e) nodname 1e-6)
        (setq brname (cadr e))
      (if (equal (cadr e) nodname 1e-6)
        (setq brname (car e))
      (if brname
        (progn
          (setq new (list brname (+ (caddr e) totdist) nodname))
          (cond
            ((member brname clnodes))
            ((setq oldpos (vl-position brname (mapcar 'car openl)))
             (setq old (nth oldpos openl))
             (if (< (cadr new) (cadr old))
               (setq openl (subst new old openl))
            (t (setq openl (cons new openl)))
          (setq edges (vl-remove e edges))
    (setq
      openl (vl-sort openl
                     (function (lambda (a b) (< (cadr a) (cadr b))))
  (setq minpath (list (list (car closedl))))
  (setq dst1 (cadr (car closedl)))
  (setq m 1)
  (foreach k closedl
    (setq dst2 (cadr k))
    (if (not (equal dst1 dst2 1e-6)) (setq m (1+ m) dst1 dst2))
  (repeat m
    (foreach n closedl
      (if (= (length minpath) 1)
        (if (equal (car n) (caddr (caar minpath)) 1e-6) (setq mp (cons n mp)))
        (mapcar '(lambda (x) (if (equal (car n) (caddr (car x)) 1e-6) (setq mp (cons n mp)))) minpath)
    (setq mp (vl-sort mp '(lambda (a b) (not (equal (car b) (car a) 1e-6)))))
      (setq minpath (mapcar '(lambda (x) (cons x (car minpath))) mp))
      (setq minpath (mapcar '(lambda (x) (mapcar '(lambda (y) (if (equal (car x) (caddr (car y)) 1e-6) (cons x y))) minpath)) mp))
    (setq minpath (mapcar '(lambda (x) (vl-remove nil x)) minpath))
    (if (listp (caaaar minpath)) (setq minpath (apply 'append minpath)))
    (mapcar '(lambda (x) (if (eq (caddr (car x)) nil) (setq minpathn (cons x minpathn)))) minpath)
    (setq mp nil)
  (setq minpathn (acet-list-remove-duplicates minpathn nil))
  (setq minpathn (vl-remove nil minpathn))
(defun make3dpl ( ptlst )
  (entmake
    (list
      '(0 . "POLYLINE")
      '(100 . "AcDbEntity")
      '(100 . "AcDb3dPolyline")
      '(66 . 1)
      '(62 . 3)
      '(10 0.0 0.0 0.0)
      '(70 . 8)
      '(210 0.0 0.0 1.0)
  (foreach pt ptlst
    (entmake
      (list
        '(0 . "VERTEX")
        '(100 . "AcDbVertex")
        '(100 . "AcDb3dPolylineVertex")
        (cons 10 pt)
        '(70 . 32)
  (entmake
    (list
      '(0 . "SEQEND")
(defun c:shortlinespath ( / osm ss i lin p1 p2 linlst ptlst g f dijkstra ptlstpths pl )
  (vl-load-com)
  (setq osm (getvar 'osmode))
  (setq ss (ssget "_:L" '((0 . "LINE"))))
  (setq i -1)
  (while (setq lin (ssname ss (setq i (1+ i))))
    (setq p1 (cdr (assoc 10 (entget lin)))
          p2 (cdr (assoc 11 (entget lin)))
    (setq linlst (cons (list p1 p2 (distance p1 p2)) linlst))
    (setq ptlst (cons p1 ptlst) ptlst (cons p2 ptlst))
  (setq ptlst (acet-list-remove-duplicates ptlst 1e-6))
  (setvar 'osmode 1)
  (setq g (getpoint "\nPick starting point on LINES NETWORK : ")
        f (getpoint "\nPick ending point on LINES NETWORK : ")
  (setq dijkstra (minpath g f ptlst linlst))
  (setq ptlstpths (mapcar '(lambda (x) (mapcar 'car x)) dijkstra))
  (mapcar '(lambda (x) (make3dpl x)) ptlstpths)
  (prompt "\nShortest path length is : ") (princ (rtos (setq len (cadr (last (car dijkstra)))))) (prompt " - you should check length to match data")
  (setq ss (ssget "_X" (list '(0 . "POLYLINE") '(70 . 😎 (cons 8 (getvar 'clayer)))))
  (setq i -1)
  (while (setq pl (ssname ss (setq i (1+ i))))
    (if (not (equal (vla-get-length (vlax-ename->vla-object pl)) len 1e-6)) (entdel pl))
  (setvar 'osmode osm)
  (textscr)
  (princ)
ronjonp
@rpajounia Take a look HERE. It's a start for you.
