<ARCHD> wrote in messageI
href="news:6137654@discussion.autodesk.com">news:6137654@discussion.autodesk.com...
have a lisp that cuts cross section profiles of polylines. Once in a while I
get this error, and I have no idea why. I do everything the same as normal,
but it happens now and again and I can't find any resolution, even if I draw
another polyline right next to the one that gives me the error, and I get the
same error on that one, even if I draw the line starting from both ends. Here
is the lsp: {code} ;;;Author: Pedro Miguel da Silva Ferreira
Email:pedro_ferreira@netcabo.pt or pferreira@wsatkins.pt ;;;Web page:
http:pwp.netcabo.pt/pedro_ferreira ;;;Location: Portugal, Lisboa ;;;RDS: PMSF
;;;Command Name: qp ;;;Date: 09 of May 2006 ;;;Version: 1.0 ;;;Description:
Visual Lisp Routine that creates a section profile of the terrain based on the
existing contours. (defun timeini () (setq s (getvar "DATE")) (setq seconds (*
86400.0 (- s (fix s)))) ) (defun timeend () (setq s1 (getvar "DATE")) (setq
seconds1 (* 86400.0 (- s1 (fix s1)))) (setq seconds2 (fix (- seconds1
seconds))) (princ (strcat "\nTime : " (itoa seconds2) " seconds" ) ) ) (defun
inivar () (setq cmd_ini (getvar "cmdecho") fla_ini (getvar "flatland") osm_ini
(getvar "osmode") ort_ini (getvar "orthomode") plt_ini (getvar "plinetype")
aup_ini (getvar "auprec") uni_ini (getvar "unitmode") lun_ini (getvar
"lunits") diz_ini (getvar "dimzin") edg_ini (getvar "edgemode") ) (setvar
"CMDECHO" 0) (setvar "FLATLAND" 0) (setvar "OSMODE" 0) (setvar "ORTHOMODE" 0)
(setvar "PLINETYPE" 2) (setvar "AUPREC" 0) (setvar "UNITMODE" 1) (setvar
"LUNITS" 2) (setvar "DIMZIN" 0) (setvar "EDGEMODE" 1) ) (defun recvar ()
(setvar "CMDECHO" cmd_ini) (setvar "FLATLAND" fla_ini) (setvar "OSMODE"
osm_ini) (setvar "ORTHOMODE" ort_ini) (setvar "PLINETYPE" plt_ini) (setvar
"AUPREC" aup_ini) (setvar "UNITMODE" uni_ini) (setvar "LUNITS" lun_ini)
(setvar "DIMZIN" diz_ini) (setvar "EDGEMODE" edg_ini) ) (defun getlayname ()
(setq contourstest nil) (setq layername (getstring "\nPlease enter the layer
name of the contours: " ) ) (setq contourstest (ssget "_x" (list (cons -4
"vla-object
ha-ename)) (vl-cmdf "._text" (vlax-curve-getstartpoint ha-object) "0" "A" )
(vl-cmdf "._text" (vlax-curve-getendpoint ha-object) "0" "B" ) ) (defun
getexaggeration () (initget 2) (setq ve (getreal "\nEnter the vertical
exaggeration <1>: ")) (if (= ve nil) (setq ve 1) ) ) (defun
listptintersect () (setq listaxy nil) (setq hazvalue (caddr
(vlax-curve-getStartPoint ha-object))) (setq curvas contourstest) (setq
ncurvas (sslength curvas)) (setq listaxy nil) (setq counter 0) (while (<
counter ncurvas) (progn (setq cnivel-ename (ssname curvas counter)) (setq
cnivel-object (vlax-ename->vla-object cnivel-ename)) (setq cnivelzvalue
(caddr (vlax-curve-getStartPoint cnivel-object)) ) (setq ha-ENTITY (subst
(cons 38 cnivelzvalue) (assoc 38 (entget (car ha))) (entget (car ha)) ) )
(entmod ha-ENTITY) (setq intersectpt (vlax-variant-value (vlax-invoke-method
ha-object "IntersectWith" cnivel-object acExtendNone ) ) ) (setq test nil)
(setq test (vl-catch-all-apply 'vlax-safearray->list (list intersectpt) ) )
(setq error (vl-catch-all-error-p test)) (if (/= error t) (progn (setq
intersectpt (vlax-safearray->list intersectpt)) (setq interlength (length
intersectpt)) (if (> interlength 3) (progn (setq dividelength (/
interlength 3)) (setq count 0) (while (< count interlength) (progn (setq
newpt (list (nth count intersectpt) (nth (+ count 1) intersectpt) (nth (+
count 2) intersectpt) ) ) (setq x (vlax-curve-getdistatPoint ha-ename newpt))
(setq z (caddr intersectpt)) (setq xy (list x (* z ve))) (setq listaxy (append
listaxy (list xy)) ) (setq count (+ count 3)) ) ) ) (progn (setq x
(vlax-curve-getdistatPoint ha-ename intersectpt)) (setq z (caddr intersectpt))
(setq xy (list x (* z ve))) (setq listaxy (append listaxy (list xy)) ) ) )
(setq ha-ENTITY (subst (cons 38 hazvalue) (assoc 38 (entget (car ha))) (entget
(car ha)) ) ) (entmod ha-ENTITY) ) ) (setq counter (1+ counter)) ) ) (setq
listaxy (vl-sort listaxy (function (lambda (e1 e2) (< (car e1) (car e2)) )
) ) ) (setq startdist (vlax-curve-getdistatPoint ha-ename
(vlax-curve-getstartpoint ha-ename) ) enddist (vlax-curve-getdistatPoint
ha-ename (vlax-curve-getendpoint ha-ename) ) ) (setq pt1 (car (car listaxy))
pt2 (car (last listaxy)) ) (if (/= startdist pt1) (progn (setq x startdist)
(setq y (+ (* (/ (- (cadr (car listaxy)) (cadr (cadr listaxy))) (- (car (cadr
listaxy)) (car (car listaxy))) ) (- (car (car listaxy)) startdist) ) (cadr
(car listaxy)) ) ) (setq xy (list x y)) (setq listaxy (append listaxy (list
xy)) ) (setq listaxy (vl-sort listaxy (function (lambda (e1 e2) (< (car e1)
(car e2)) ) ) ) ) ) ) (if (/= enddist pt1) (progn (setq pos (1- (length
listaxy))) (setq x enddist) (setq y (+ (* (/ (- (cadr (nth pos listaxy)) (cadr
(nth (1- pos) listaxy)) ) (- (car (nth pos listaxy)) (car (nth (1- pos)
listaxy))) ) (- enddist (car (nth pos listaxy))) ) (cadr (nth pos listaxy)) )
) (setq xy (list x y)) (setq listaxy (append listaxy (list xy)) ) (setq
) ) ) ) ) ) (defun createprofile () (setq variante-listaxy (apply 'append
listaxy)) (setq arraySpace (vlax-make-safearray vlax-vbdouble (cons 0 (-
(length variante-listaxy) 1) ) ) ) (setq variante-listaxy (vlax-safearray-fill
arraySpace variante-listaxy) ) (vlax-make-variant variante-listaxy) (setq
pline (vla-addLightweightPolyline *ModelSpace* variante-listaxy ) ) (vl-cmdf
"._text" (vlax-curve-getstartpoint pline) "0" "A" ) (vl-cmdf "._text"
(vlax-curve-getendpoint pline) "0" "B" ) ) (defun annotate () (setq xini (car
(vlax-curve-getstartpoint pline)) xend (car (vlax-curve-getendpoint pline)) y
(* (fix (/ (cadr (car (vl-sort listaxy (function (lambda (e1 e2) (< (cadr
e1) (cadr e2)) ) ) ) ) ) ve ) ) ve ) ) ;;end setq (if (< y 0) (setq y (- y
(* 1 ve))) ) (setq var-xyini (apply 'append (list (list xini y 0)))) (setq
var-xyend (apply 'append (list (list xend y 0)))) (createline) (setq yref
(strcat "REFERENCE: " (rtos (/ y ve) 2 2))) (setq ptloc (list (- xini 30.0)
y)) (vl-cmdf "._text" ptloc "0" yref) (setq lengthlistaxy (length listaxy))
(setq count 0) (while (< count lengthlistaxy) (progn (setq var-xyini (apply
'append (list (list (car (nth count listaxy)) (cadr (nth count listaxy)) 0 ) )
) ) (setq var-xyend (apply 'append (list (list (car (nth count listaxy)) y 0))
) ) (createline) (setq ytext (rtos (/ (cadr (nth count listaxy)) ve) 2 2))
(setq xpt (car (nth count listaxy))) (setq ptloc (list xpt (- y 10.0)))
(vl-cmdf "._text" ptloc "90" ytext) (setq count (1+ count)) ) ) ) (defun
createline () (setq arraySpace (vlax-make-safearray vlax-vbdouble (cons 0 (-
(length var-xyini) 1) ) ) ) (setq var-xyini (vlax-safearray-fill arraySpace
var-xyini) ) (vlax-make-variant var-xyini) (setq arraySpace
(vlax-make-safearray vlax-vbdouble (cons 0 (- (length var-xyend) 1) ) ) )
(setq var-xyend (vlax-safearray-fill arraySpace var-xyend) )
(vlax-make-variant var-xyend) (setq line (vla-addline *ModelSpace* var-xyini
var-xyend ) ) ) (defun c:qp () (timeini) (inivar) (getlayname) (esttexto)
(getha) (getexaggeration) (listptintersect) (createprofile) (annotate)
(vl-cmdf "._zoom" (vlax-curve-getstartpoint pline) (vlax-curve-getendpoint
pline) ) (recvar) (timeend) (princ) ) {code} Here is the error: {code}
Command: qp Please enter the layer name of the contours: btw-xsec Select the
Horizontal alignment: Enter the vertical exaggeration <1>: 1 error: bad
argument type: numberp: nil; error: An error has occurred inside the *error*
functionAutoCAD variable setting rejected: "PICKBOX" nil {code} Any help or
ideas whould be appreciated. If you have a lisp that cuts cross section
profiles that is simple to use, that would help also. Thanks Edited by: ARCHD
on Mar 6, 2009 11:45 AM
