Quick OSNAPZ Alias command
I need a quick guide on how to make an IF-function for my OSNAPZ command, though I'm not that used to writing scripts for AutoCAD
I'm switching between OSNAPZ=0 and OSNAPZ=1 so often that I'd like it so that I only use one quick command instead of the double command each time. Basically I want this function:
defun c:o
   if OSNAPZ=1
      OSNAPZ=0
   else
      OSNAPZ=1
So I can basically switch between OSNAPZ=1 and OSNAPZ=0 with just a simple "O"+Enter command.
ВeekeeCZ
(defun c:O () (princ "> OSNAPZ changed to ") (setvar 'OSNAPZ (- 1 (getvar 'OSNAPZ))))
If you ever want to use that transparently, you need to type 'O. Or assign a shortcut (eg. Ctrl+O) to it.
Thanks!
Works perfectly!
scot-65
You may also try the following:
(setvar "MODEMACRO" "OSNAPZ= $(getvar,OSNAPZ)")
Place inside S::STARTUP (acaddoc.lsp)
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
