Query Layer Properties Editing Command Line
joe_schmidtR6QZX
joe_schmidtR6QZX
I need a command that can find any layer with a specified word contained in the layer name and select those layers. Similar to how searching *mech* in the layer properties menu will bring back any layer with "mech" in it. How do I do this but in the command line.
TLDR: select layers containing specific characters (and change their properties) through command line.
Kent1Cooper
Change the properties of all such Layers to the same settings?  All the same color, or linetype, or...?  You can already do that -- use the hyphen-prefixed -LAYER command, and choose an option [other than Make or Set] and a value for it, and give it the Layer name(s) to assign that to with wildcards just as you describe, for example *mech* [it's not even case-sensitive].
Kent Cooper, AIA
joe_schmidtR6QZX
Not sure why this wasn't working earlier but its working now. Thank you!
