Qdim using aligned instead of linear
WarrenDeSouza
Observer Observer
WarrenDeSouza
Observer
Observer
I have a poly line with multiple segments. Some segments are straight lines, others are arcs.  For the straight line segments, I need it to dimension using aligned. for the arcs, I need it to dimension using  arc length.
When I use the Qdim function on this poly line, it only gives linear Dimensions.
Is there anyway to achieve what I want using a custom command macro or will it require AutoLisp?
hak_vz
@WarrenDeSouza
Welcome to the Visual lisp forum.
Whenever you post your request attach sample dwg that shows your typical problem situation. In this case attach a drawing with an appropriate dimension style that you use. This helps a lot.
Miljenko Hatlak
adrianRCSX8
Community Visitor
Community Visitor
Ok this is a bit late I know, but I just had this issue and I wanted to see if anyone had a solution.
I did find a work around with mine, see below.
I changed the UCS to align with the lines that I wanted to add dimensions too. Afterwards, QDim works perfectly for dimensioning.
I hope this helps other people also looking for solutions without needing to use AutoLisp.
Kent1Cooper
Does DimPoly.lsp >here< do what you want?  Look through earlier Messages in that topic, and/or Search for DimPoly for other Topics that contain other versions of it, in case there are differences that matter to you.
Kent Cooper, AIA
