QDIM BLOCK
QDIM BLOCK
Ahmed_204
Message 1 of 14
QDIM BLOCK
Ahmed_204
Good day ,
I would like to change something in this code that instead of choosing "pt" as dimension line location , I would like to see all the dimensions appear  after that choose where to put them. "The same idea of QDIM"
(vl-load-com)
(defun C:FH ( / *error* doc oVAR ss i pts ptsx ptsy d d0 filter)
   (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg)))
    (foreach e oVAR (setvar (car e) (cdr e)))
    (vla-endundomark doc)
    (princ))
  (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object))))
  (foreach e '(CMDECHO ORTHOMODE)
    (setq oVAR (cons (cons e (getvar e)) oVAR)))
  (setvar 'CMDECHO 	0)
  (setvar 'ORTHOMODE 	0)
  (if (and (princ "\nNeed blocks, ")
               (setq ss (ssget (list '(0 . "INSERT"))))
	   (< 1 (setq i (sslength ss)))
	   (while (not (minusp (setq i (1- i))))
	     (setq pts (cons (cdr (assoc 10 (entget (ssname ss i)))) pts)))
	   (setq ptsx (vl-sort pts '(lambda (p q) (< (car  p) (car  q)))))
	   (setq ptsy (vl-sort pts '(lambda (p q) (< (cadr p) (cadr q)))))
	   (setq d (abs (/ (- (car  (last ptsx)) (caar  ptsx))      ;xmax-xmin
			   (if (zerop (setq d0 (- (cadr (last ptsy)) (cadar ptsy)))) ;ymax-ymin
			     0.001
			     d0))))
	   (setq pt (getpoint "\nSpecify dimension line location: "))
	   (or *DimTypeBDA
	       (setq *DimTypeBDA "Aligned"))
	   (not (initget "Horizontal Vertical Aligned"))
	   (setq *DimTypeBDA (cond ((getkword (strcat "\nType of dimension ["
						      (cond ((> d 1000.) (if (= *DimTypeBDA "Vertical") (setq *DimTypeBDA "Horizontal")) "Horizontal")
							    ((< d 0.001) (if (= *DimTypeBDA "Horizontal") (setq *DimTypeBDA "Vertical")) "Vertical")
							    ("Horizontal/Vertical"))
						      "/Aligned] <" *DimTypeBDA ">: ")))
				   (*DimTypeBDA)))
	   (setq pts (if (or (= *DimTypeBDA "Horizontal")
			     (and (= *DimTypeBDA "Aligned")
				  (> (- (car (last ptsx))  (caar ptsx))
				     (- (cadr (last ptsy)) (cadar ptsy)))))
		       ptsx
		       ptsy))
	   (setq i 0)
    (repeat (1- (length pts))
      (cond ((= *DimTypeBDA "Horizontal")
	     (command "_.DIMLINEAR"
			"_none" (nth i pts)
			"_none" (nth (1+ i) pts)
			"_H"
		      "_none" pt))
	    ((= *DimTypeBDA "Vertical")
			"_none" (nth i pts)
			"_V"
			"_none" pt))
	    (T ;Aligned
	       (command "_.DIMALIGNED"
			"_none" (nth i pts)
			"_none" pt)))
      (setq i (1+ i))
    (princ (strcat "\nError: Wrong selection of at least 2 BLOCKS.")))
  (princ)
Replies (13)
Message 2 of 14
devitg
Would you, please, upload the sample.dwg, with and before and after?
Message 3 of 14
Ahmed_204
Good Day,
I don't know how to show you this on a sample drawing but I will tell you exactly what I need.
when you try this code you will find that all the dimensions will appear one time at the end of executing the code in    the location of point "pt".
I want all the dimension to appear first after that i click where i want to place those dimensions like exactly what you do while using QDIM command in Autocad.
Thank you for your support.
Message 4 of 14
CADaSchtroumpf
Perhaps this?
(vl-load-com)
    (princ))
  (setvar 'CMDECHO 	0)
			     0.001
			     d0))))
	   ;(setq pt (getpoint "\nSpecify dimension line location: "))
	   (or *DimTypeBDA
				   (*DimTypeBDA)))
		       ptsx
		       ptsy))
	   (setq i 0)
			"_none" (nth i pts)
			"_H"
		      "_none" pause))
			"_none" (nth i pts)
			"_V"
			"_none" pause))
	    (T ;Aligned
			"_none" (nth i pts)
			"_none" pause)))
      (setq i (1+ i))
  (princ)
Message 5 of 14
Ahmed_204
I tried to solve it like that yesterday but it will keep asking the user for the dimension location for each dimension created between blocks because the Dimlinear inside a repeat loop.
I want the lisp to create all the dimension first and show it on screen and wait for the user to choose the location.
I am thinking about storing all the dimensions created in a variable then delete them and call this variable which will  allow the user to put the dimension in the desired location. "Just an idea"
 Thanks.
Message 6 of 14
devitg
Please upload a sample.dwg with such  INSERT'ed  blocks . It just what I need to check your lisp
Message 7 of 14
Ahmed_204
Good Day ,
I attached a sample drawing.
Thanks for your support.
Message 8 of 14
Ahmed_204
HI @cadffm ,
Can you support me in this issue as well ?
Message 9 of 14
phanaem
Hi
I use this lisp to QDIM blocks. It works like native QDIM, but allows blocks to be selected and measure at the insertion point.
If you want only blocks, change this line ... (setq ss1 (ssadd) ss (ssget '((0 . "INSERT))))
(defun c:qqd ( / *error* acDoc ss1 ss i e)
  (setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (vla-StartUndoMark acDoc)
  (defun *error* (msg / i)
    (if
      (not (eq msg "Function cancelled"))
      (princ msg)
    (repeat (setq i (sslength ss1)) (entdel (ssname ss1 (setq i (1- i)))))
    (vla-EndUndoMark acDoc)
  (if
    (setq ss1 (ssadd) ss (ssget))
    (progn
      (repeat (setq i (sslength ss))
        (if
          (eq (cdr (assoc 0 (entget (setq e (ssname ss (setq i (1- i))))))) "INSERT")
          (ssadd (entmakex (list '(0 . "POINT") (assoc 10 (entget e)))) ss1)
      (command "_QDIM" ss ss1 "")
      (while (> (getvar 'cmdactive) 0)
        (command pause)
  (*error* nil)
  (princ)
Message 10 of 14
cadffm
I guess you need two things:
a) How to identifier depend the cursor position (first step simply use one static sample/your sample.dwg and three different static coordinates as cursorposition for H/V/A)
b) Read about GRREAD to read coordinates of cursorposition and more.
Sorry, now time to show all the way.
GoodLuck, you will find a lot of samples in www
The Preview is not a problem, just create your dimensions..
you can delete&re-create or edit the dimension easily.
S
Sebastian
Message 11 of 14
Ahmed_204
Hi @phanaem
Your Solution would be perfect if it applies also with aligned dimension but its also good.
Message 12 of 14
Ahmed_204
Good Day ,
I found the solution for this issue by getting support from CadTutor
I attached the final lisp here.
Thank you all for your support & effort.
Message 13 of 14
arpansark0544TCX
This lisp is very useful. Thank you
Message 14 of 14
Ahmed_204
You are welcome @arpansark0544TCX
