Python SendCommand PLOT convert to jpeg
I am using python to convert dwg to jpeg.
Currently, I am using SendCommand and "_-PLOT" to convert to jpg:
acad = win32com.client.dynamic.Dispatch("AutoCAD.Application")
doc = acad.ActiveDocument
doc.SendCommand('_-PLOT ' 'T \n' 'Model \n' 'plotter_ARD\n' +str(size)+'\n' 'Pionowo\n' 'Nie\n' 'Zakres\n' 'Dopasuj\n' '\n' 'Nie\n' '.\n'  'Tak\n' '\n' 'N\n' 'T\n')
everything works correctly, but there is a file dialog in the end:
I would like to fill it without pyautogui. Is there a way to fill it with python AutoCAD libraries?
cadffm
Change the content of your sendcommand (you can built a Lisp-Statement as string and send this to the commandline)
I am not familiar with the phyton syntax for string handling,
my mother language is german, not english or polski,
but the result (in AutopCAD) should looks like this:
(command "_.-PLOT" "_yes" "Model" "plotter_ARD" "YourPaperSizeNameHere" "Pionowo" "Nie" "Zakres" "Dopasuj" "" "Nie" "." "Tak" "" "Nie" "Tak")
The whole line AS ONE STRING, 1:1 as i post it incl. the ""
OR: Set FILEDIA to 0 first, plot, set Filedia back to the previous value.
Sebastian
Thank you for your answer!
I set FILEDIA to 0 and now I can set directory in CommandLine.
