pyautocad inserting block and rotation
john_stimacH3EQQ
john_stimacH3EQQ
I'm having some issues writing a script that inserts a block at a specific point and then rotates the block based on a reference angle captured earlier in the python script. Everything works pretty well, but the issue is that the blocks are coming in with additional rotation added to it. The python debug files do not show this behavior. The script is using the pyautocad InsertBlock function. Is there any significant differences between that function and the vla-InsertBlock AutoCAD ActiveX/COM interface command that could possibly be causing this?
daniel_cadext
model.InsertBlock and vla-InsertBlock should be the same, rotation is in radians
I’m currently not setup with pyautocad, using my wrappers which also use win32com, InsertBlock works as advertised
import traceback
from pyrx_impx import Rx, Ge, Gi, Db, Ap, Ed, Ax
# creates a new command xdoit
def PyRxCmd_xdoit():
    try:
        axApp = Ax.getApp()
        path = "M:\\Dev\\Projects\\PyRxGit\\PySamples\\dwg\\18X36RP.dwg"
        x : Ge.Vector3d= Ge.Vector3d.kXAxis
        y : Ge.Vector3d= Ge.Vector3d.kYAxis
        z : Ge.Vector3d= Ge.Vector3d.kZAxis
        ref = axApp.ActiveDocument.ModelSpace.InsertBlock((0, 0, 0), path, 1, 1, 1,  x.angleTo(y,z))
    except Exception as err:
        traceback.print_exception(err)
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
john_stimacH3EQQ
knowing that they both insert in radians helped. Thanks
