Put dimension objects on layers according to dimention style name
GeryKnee
GeryKnee
How could be a lisp command that after call (Undo Start here)
1) Looks inside mode space for all the dimension object
2) Fo every dim object  objI
    Let the obj.style DsJ named be "NDSJ"
    If there isn't a layer named "Dim_NDSJ" creates a new layer named "Dim_NDSJ" with layer.Color
    the    DsJ.TextColor
    If theres a layer named "Dim_NDSJ" changes the layer.Color to DsJ.TextColor
3) After all Halts and Undo Ends
Thans,
Gery
ВeekeeCZ
Here is something to start with. It dose not all you want, but I guess you're skilled enough to figure it out by yourself.
(vl-load-com)
(defun c:DimSortByStyle ( / ss ent stl lay)
  (vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
  (if (setq ss (ssget "_X" '((0 . "DIMENSION") (410 . "Model"))))
    (repeat (setq i (sslength ss))
      (setq ent (ssname ss (setq i (1- i))))
      (setq stl (getpropertyvalue (getpropertyvalue ent "DimensionStyle") "Name"))
      (setq lay (strcat "Dim_" stl))
      (if (or (tblsearch "LAYER" lay)
              (vl-cmdf "_.-LAYER" "_N" lay "" "")
        (setpropertyvalue ent "LayerId" (tblobjname "LAYER" lay)))))
  (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
  (princ)
GeryKnee
Sorry,
getpropertyvalue isn't recognized from my old Autocad 2006 version.
Do you have solution about it?
utocad text window:
Command: DimSortByStyle
; error: no function definition: GETPROPERTYVALUE
Command:
Thanks for your time
Gery.
ВeekeeCZ
Sure. Plain AutoLisp.
(vl-load-com)
      (setq ent (entget (ssname ss (setq i (1- i)))))
      (setq stl (cdr (assoc 3 ent)))
              (vl-cmdf "_.-LAYER" "_N" lay "")
        (entmod (subst (cons 8 lay) (assoc 8 ent) ent)))))
  (princ)
GeryKnee
Yes,
That's perfect.
Thank you very match for your time.
Gery
ВeekeeCZ
Just for your info since you quite new around here. By marking solution you give the info to other potential users searching for similar issue, that your issue was solved AND by this or that post to get quick overlook over the topic conversation. So don't mark your msg where you're saying "its not working."
