purge without opening dwg
(defun c:tt1()
    ;; This example creates a Circle object and uses the CopyObjects
    ;; method to make a copy of the new Circle.
    (setq acadObj (vlax-get-acad-object))
    (setq doc (vla-get-ActiveDocument acadObj))
    ;; Load the ObjectDBX library
    (if	(= acLibImport nil)
			(progn
				(vlax-import-type-library
					:tlb-filename
					"C:\\Program Files\\Common Files\\Autodesk Shared\\axdb18enu.tlb"
					:methods-prefix
					"acdbm-"
					:properties-prefix
					"acdbp-"
					:constants-prefix
					"acdbc-"
				(setq acLibImport T)
    (setq acdbObj (vlax-create-object "ObjectDBX.AxDbDocument.18"))
    (acdbm-open acdbObj (findfile "C:/test.dwg"))
		(Vlax-Invoke-Method acdbObj 'purgeall)
		(Vlax-Invoke-Method acdbObj 'SaveAs "C:/test.dwg")
    ;; Close the in memory drawing
    (vlax-release-object acdbObj)
I think I can not purge via DBX.
So what can I do with DBX?Is there a list of methods that I can use via DBX?
_gile
You can only use the ActiveX interface.
Gilles Chanteau
GileCAD
GitHub
But it can not find purgeall method via DBX
_gile
No you can't use PurgeAll.
To get all available properies and method for acadObj, do:
(vlax-dump-object acadObj T)
Gilles Chanteau
GileCAD
GitHub
