Hi all,
So i tried my first reactor, a copy past story :p. and then i put my function in it.
It works fine but one thing i still missing, and thats a purge from a specific block, I already learned that a command purge can't be excuted in a reactor and that there is a purgeall. But is it possible without a purgeall, and like purge the block (green text)..
Also i m running this reactor at a close command, but i would be problaby better if i run it with a certain command like a delete command.
if you need more informatie, the reactor looks into 2 textfiles (one with all titleblocks in a project) (and one with all titleblocks in that drawing) . It checks of there all blocks equal to that textfile still exist, and if not, it adjust the 2 textfiles...
also it works with another textfile where it asking the projectnumber if not created.
;; CLOSE reactor
(vl-load-com)
(defun smart-command-reactor (commands StartCallback EndCallback / ended)
(vl-load-reactors)
(setq ended
(vlr-command-reactor nil
(:vlr-commandEnded . internal-commandEnded)
(:vlr-commandCancelled . internal-commandEnded)
(:vlr-commandFailed . internal-commandEnded)
(vlr-remove ended)
(list
ended
StartCallback
EndCallback
(if (listp commands)
(mapcar 'strcase commands)
(list (strcase commands))
'((:vlr-commandWillStart . internal-commandWillStart))
(defun internal-commandWillStart (reactor args / data result)
(setq data (vlr-data reactor))
(if
(and
(member (car args) (last data))
(setq result (apply (cadr data) (list (car args))))
(progn
(vlr-data-set
(car data)
(list (caddr data) result)
(vlr-add (car data))
(defun internal-commandEnded (reactor args / data)
(vlr-remove reactor)
(apply
(car data)
(list
reactor
(vlr-current-reaction-name)
(car args)
(cadr data)
(if *my-smart-close-reactor* (vlr-remove *my-smart-close-reactor*))
(setq *my-smart-close-reactor*
(smart-command-reactor
;; command(s) as list
'("CLOSE")
;; StartCallback (called when CLOSE starts)
(function
(lambda (cmdname)
;;; *** from here
;;; (vla-ZoomExtents (vlax-get-acad-object))
(setq Listtxt nil)
(setq Newlist nil)
(setq Removelist nil)
(setq OldList nil)
(setq DWGprefix (getvar "dwgprefix")
Externfolder (strcat DWGprefix "\\#Library-Do Not Edit#")
Localfolder (strcat "C:\\Autodesk-library")
DWGprefixL (strlen DWGprefix)
Last4letters (substr DWGprefix (- DWGprefixL 4) 4)
DWGname (getvar "dwgname")
DWGnameL (strlen DWGname)
DWGname (substr DWGname 1 (- DWGnameL 4))
BlockUsed (strcat Externfolder "\\BinTitleBlock.txt")
TxtForDwgTitleblock (strcat Externfolder "\\Bin"DWGname"Titleblock.txt")
project (strcat Externfolder "\\BinProjectBlock.txt")
Activedoc (vla-get-activedocument (vlax-get-acad-object)))
(if (not(vl-file-directory-p Localfolder))
(vl-mkdir Localfolder)
(if (eq Last4letters "ACAD")
(progn
(if (not (open project "R"))
(progn
(if(not(setq dcl_id (load_dialog "PROJECTNUMBER.dcl")))
(progn
(alert "The DCL file could not be loaded!")
(exit)
);PROGN
(progn
;;;--- Load the definition inside the DCL file
(if (not(new_dialog "PROJECTNUMBER" dcl_id))
(progn
(alert "The DOSSIER definition could not be loaded!")
(exit)
);PROGN
(progn
(action_tile "DOSSIERNUMMER" "(setq Projectnumber $value)")
(start_dialog)
(unload_dialog dcl_id)
(setq file (open project "W"))
(write-line (strcat Projectnumber) file)
(close file)
(progn
(setq file (open project "R"))
(setq Projectnumber (read-line file))
(close file)
(if
(not(vl-file-directory-p Externfolder))
(vl-mkdir Externfolder)
(if
(open TxtForDwgTitleblock "r")
(progn; first argument 1.1.1
(setq file (open TxtForDwgTitleblock "R"))
(while (setq Txtline (read-line file))
(setq Listtxt (cons Txtline Listtxt)))
(close file)
(setq Listtxt (reverse Listtxt))
(setq Listtxt nil)
(if
(not(eq Listtxt nil))
(progn
(foreach x Listtxt
(setq ListX x)
(if (and
(not (eq (tblsearch "block" ListX) nil))
(ssget "_X" '((0 . "INSERT")(66 . 1)))
(vlax-for block (vla-get-ActiveSelectionSet Activedoc)
(if
(= (strcase (vlax-get-property block 'EffectiveName)) (strcase ListX))
(progn
(setq Newlist (cons ListX Newlist))
);Progn
(princ Newlist)
(foreach x Listtxt
(setq ListtxtX x)
(if (not(member ListtxtX Newlist))
(setq Removelist (cons ListtxtX Removelist))
(princ Removelist)
(setq file (open TxtForDwgTitleblock "W"))
(close file)
(setq Start (vl-string-search (strcat "\\" "\\") (strcat TxtForDwgTitleblock)))
(if (not (eq Newlist nil))
(progn
(setq Newlist (Reverse Newlist))
(foreach x Newlist
(setq file (open TxtForDwgTitleblock "A"))
(write-line (strcat x) file)
(close file)
(if (not (eq Removelist nil))
(progn
(if
(open BlockUsed "R")
(progn
(setq file (open BlockUsed "R"))
(setq OldList (cons Txtline OldList)))
(close file)
(setq OldList (reverse OldList))
(setq file (open BlockUsed "W"))
(foreach x OldList
(setq OldListX x)
(if (member OldListX Removelist)
(progn
(Alert (strcat "You deleted block " OldListX ", This has been removed from the settings."))
;;; (COMMAND "_purge" "BLocks" OldListX "_N")
(progn
(write-line (strcat OldListX) file)
);if
);foreach
(close file)
);progn
);progn
(setq Listtxt nil)
(setq Newlist nil)
(setq OldList nil)
;;; (alert "Command CLOSE was issued.")
;;; *** to here
;; EndCallback (called when CLOSE ends)
(function
(lambda (data)
(setvars data)
(sssetfirst nil)
(setq app nil adoc nil)
(defun setvars (data)
(mapcar
(function
(lambda (v / r)
(setq r (getvar (car v)))
(setvar (car v) (cdr v))
(cons (car v) r)
data
(princ "\nCLOSE reactor enabled.")
(princ)
