Publish to separate PDFs (using routine)
Millwood-k
Message 1 of 15
Millwood-k
Hello there,
I have this simple nice routine to customize (Export to separate DWG with customize extension),
Can anyone adapt it to (Publish to separate PDF with customize extension)
*here is the script:
(defun c:ltodwg ( / base old_dia)
(if (null LM:browseforfolder)
(load "BrowseForFolderV1-3")
(if (setq base (LM:browseforfolder "Select a folder" " C:\\" 1))
(progn
(setq old_dia (getvar 'FILEDIA))
(setvar 'FILEDIA 0)
(setq base (strcat base "\\" (vl-filename-base (getvar 'DWGNAME))))
(foreach lay (layoutlist)
(command "_.ctab" lay "exportlayout" (strcat base "-" lay "_CAD_2021"))
(setvar 'FILEDIA old_dia)
); progn
); if
(princ)
apreciation.
Replies (14)
Message 2 of 15
cgooding
If I understand correctly, you want to publish to separate PDF files instead of a single multipage file.
I just use the publish command, and change the settings to uncheck "Multi-sheet file".
This creates separate PDF files with naming convention "Dwg Name-Tab Name.pdf"
Hope this helps.
Message 3 of 15
Millwood-k
thanks for the answer,
Yes, but the way showed doesn't allow you to add extension (to each separate pdf), and doesn't allow you to use only Layout name, which this routine if adapted can do.
Message 4 of 15
cgooding
Sorry, I'm just curious: What is the purpose of adding extension?
Message 5 of 15
maratovich
@Millwood-k  написал (-а):
Then you have to use Lisp for printing or program.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 6 of 15
cgooding
Now I wonder if I should just delete my original response since it didn't answer your question! 😐
Message 7 of 15
Millwood-k
I do have 100s layout in each dwg file, and need to publish them as fellow
XLayout name+CAD_2021, (X variable from file to file), and the file name doesn't have to be shown.
Message 8 of 15
maratovich
www.kdmsoft.net
Message 9 of 15
Millwood-k
Your solution works for other needed cases,
Message 10 of 15
Millwood-k
I haven't seen this, is it a third part app ?
Message 11 of 15
Millwood-k
Actually I do have LayoutManager app, but for some reason I am looking for a simple routine.
Message 12 of 15
maratovich
Here it is - Revers
www.kdmsoft.net
Message 13 of 15
john.uhden
No offense, but can't you just use sheet set manager?
There are PDF publish options where you can toggle off Multi-sheet PDF.
You get a separate PDF for each sheet.
My boss prefers that because he never remembers to scroll down or page down, and then asks where the rest of the sheets are.
John F. Uhden
Message 14 of 15
pendean
Community Legend
Community Legend
All you need is a batch processor: run your lisp in 100s of DWG files since that's all you really want to do (aka simple). There are dozens of recommendations in this forum and on the web, some are free many of the good ones are not. Help yourself.
Here is one https://www.kdmsoft.net/autorunlisp.html
and another https://apps.autodesk.com/ACD/en/Detail/Index?id=4355599973554868100&appLang=en&os=Win32_64
and more https://www.google.com/search?q=run+lisp+in+multiple+drawings
HTH
Message 15 of 15
Sea-Haven
The Maratovich proposal is the way to go, I do have a plot layouts by range so can plot 1-100 etc or 34-37 and so on all will be seperate, its lisp so could add the extra pdf name stuff. I use ghostscript to join them back into 1 pdf as a option also part of the lisp.
