publish in one click
smallƑish
smallƑish
Is that possible to make these steps in one click?
Publish - Delete all models - select all layouts and change page setup of the first layout - publish to pdf at the desktop.
ВeekeeCZ
Why delete models? Learn how to not add them to the list in the first place.
pendean
Community Legend
Community Legend
I guess you are not aware of this setting when you right click in the window and uncheck it once and it sticks forever and ever until you change it back
Do you use SSM by chance? Goes a long way to automating PUBLISH as well, plus tons of organizing goodies come with it including an automatic sheetlist.
HTH
Sea-Haven
We have for years plotted 1 click and goes to correct printer, dont use publish but rather a lisp, stuff like plot 88 layouts in one go, just click on menu option. Happy to provide more info.
smallƑish
Can you please share more info to avoid publish and alternative method?
Sea-Haven
There are lots of lisps out there that do Plot of layouts, for us a couple of simple rules 1 title block per layout, title block was always at 0,0. We only used 1 company title block.
Ok step 2 had a move title blocks to 0,0 for the guys that screwed stuff up.
I am in the process for a client of doing mixed sheet sizes and orientation again 1 click on a menu, but all title blocks are known and no odd ones.
You can have a play with this needs Multi getvals.lsp you will have to change the corner settings and possible output sheet size we used a A1 size title block. There is version 2 which joins all the individual pdfs back into 1. It uses Ghostscript to combine the pdf's
