Propulate LISP
Propulate LISP
Joe.Gio
Propulate LISP
Joe.Gio
Hi All,
Does anyone have a lisp that will run the 'propulate' command and select the correct file by reading the border block?
So if the block name is 'A3_Template' it will read that, select the appropriate matching .prp file in a dedicated folder and apply it followed by running 'regen' at the end?
Thanks.
Joe.Gio
Hi All,
Would anyone know someone who is able to assist with this LISP at all?
Thanks.
Michiel.Valcke
the propulate command is an express tool and cannot be used in a (command "propulate" type of function...) so you would need to recreate part of its functionality.
You might want to take a look at this post and this post they contains several snippits of code how to retrieve the values of custom properties and how to set them.
