Proper way to explode entity
SaddamShaikh77
SaddamShaikh77
Hello forum,
I am trying to explode entities as per the following ways.
1. editor.command("EXPLODE",ent.id);
It did work for me when I was selecting entity manual from AutoCAD. But when I automated the process of selection it failed.
2. Then I tried document.SendStringToExecute("EXPLODE \n"+entobject+"\n",true,false,false);
It also failed for me.
3. Then I have tried,
(Entity)myObject.Explode(DB collection);
It worked for me.
Problem: The entity for explode is polyline. When I am exploding it manually I am getting set of 5 lines and same I am getting in approach 1. When I am using third approach for exploding the same entity(i.e polyline), I am getting 10 lines instead of 5 which is affecting my further work.
Please help me understand where I am making mistake. If is there any way to achieve this?
Thank you.
Kent1Cooper
I'm not familiar with that kind of code.  There are several other Customization Forums for different programming languages, >here<, if one of those is for the one you're using.
Kent Cooper, AIA
