Progress bar for looping through foreach section of program
Travis.Biddle
Travis.Biddle
I have a program that reads all .txt files from a certain folder and then draws items based off the information found in those .txt files.  Sometimes there may be 5 files, sometimes there may be 250.  Is it possible to implement a progress bar so the impatient users dont think its crashed.  I am able to pull the number of files ahead of time and set a variable "NUMOFTXT".  I have found some progress bar/meter programs, but am having troubles implementing them into the loop.  Below is the code (modified portion of the original code written by @Kent1Cooper
(setq numoftxt (vl-directory-files FOLDER "*.txt" 1))
(SETQ NUMOFTXT (LENGTH NUMOFTXT))
(foreach txtfile (vl-directory-files folder "*.txt" 1)
(command "zoom" "w" zoompt1 Zoompt2)
(setq file (open (strcat folder txtfile) "r"))
(while (setq txt (read-line file))
(cond
((wcmatch (vl-string-trim "\t " txt) "'= FILENAME=*")
(setq txt (afterequal) txt (afterequal)); bypass (2) = signs;
(command "layer" "s" "Filename" "")
(command "_.text" "_style" "FILE" "_r" "_none" labeltxtins 0 txt)
); filename-line condition
((wcmatch (vl-string-trim "\t " txt) "TOOL*");;Start of identifying TOOL number
(setq
ToolStr (afterequal); Text string
); setq
); TOOL Number condition---Checks TOOL number in line and sets the # i.e. TOOLNAME=108 will return "108"
((wcmatch (vl-string-trim "\t " txt) "LINE*")
(setq
txt (afterequal) startX (atof (tocomma))
txt (afterequal) startY (atof (tocomma))
txt (afterequal) startZ (atof (tocomma))
txt (afterequal) endX (atof (tocomma))
txt (afterequal) endy (atof (tocomma))
endZ (atof (afterequal))
); setq
(command "layer" "s" toolstr "")
(command "_.line"
"_none" (setq lstart (list (+ startX shift) startY startZ))
"_none" (setq lend (list (+ endX shift) endY endZ))
); command
(setq toolstr nil)
(if part ; in a part box?
(if (= lineNo 0); then [outer] -- drew first Line of part box
(setq ; then [inner]
p1 lstart
p2 lend
lineNo 1 ; triggers part Text after next Line
); setq
(progn ; else [inner] -- second Line of part box
(setq ; then
p3 lstart
p4 lend
); setq
(command
"_.text" "_style" "PART" "_none" "_mc"
(mapcar '/ (mapcar '+ (mapcar 'min p1 p2 p3 p4) (mapcar 'max p1 p2 p3 p4)) '(2 2))
0 partStr
); command
(setq part nil); [other 2 part-box Lines ordinary]
); progn
); if [which Line just drawn]
); if [in part box]
); LINE condition
((wcmatch (vl-string-trim "\t " txt) "POINT*")
(setq
txt (afterequal) ptX (atof (tocomma))
txt (afterequal) ptY (atof (tocomma))
ptZ (atof (afterequal))
); setq
(command "layer" "s" toolstr "");;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(command "_.point" "_none" (list (+ ptX shift) ptY ptZ))
); POINT condition
((wcmatch (vl-string-trim "\t " txt) "ARC*")
(setq
txt (afterequal) ; bypass Z
txt (afterequal) endY (atof (tocomma))
txt (afterequal) ctrX (atof (tocomma))
txt (afterequal) ctrY (atof (tocomma))
); setq
(command "layer" "s" toolstr "");;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(command "_.arc"
"_none" (list (+ startX shift) startY)
"_c" "_none" (list (+ ctrX shift) ctrY)
"_none" (list (+ endX shift) endY)
); command
); ARC condition
((wcmatch (vl-string-trim "\t " txt) "PART*")
(setq
part T ; triggers use of next 2 Line specs to locate part Text
partStr (afterequal); Text string
lineNo 0
); setq
); PART-line condition
;; [no none-of-the-above condition; do nothing with other lines]
); cond
); while [lines in file]
(command "mirror" "w" mirrpt1 mirrpt2 "" midpt3 midpt4 "y")
(command "layer" "s" "customer" "")
(setq ; to shift next results over
shift (+ shift shiftinc)
labeltxtins (polar labeltxtins 0 shiftinc)
mirrpt1 (polar mirrpt1 0 shiftinc)
mirrpt2 (polar mirrpt2 0 shiftinc)
midpt1 (polar midpt1 0 shiftinc)
midpt2 (polar midpt2 0 shiftinc)
midpt3 (polar midpt3 0 shiftinc)
midpt4 (polar midpt4 0 shiftinc)
zoomt1 (polar midpt1 0 shiftinc)
zoomt2 (polar midpt2 0 shiftinc)
); setq
); foreach
Moshe-A
@Travis.Biddle ,
check this, express tools provide us (acet-ui-progress) function. search the web for help on it
enjoy
Moshe
(defun c:pgbar ()
; init meter, numoftxt can not be more than (expt 2 15) = 32767
 (if (and (setq lstFiles (vl-directory-files FOLDER "*.txt" 1))
          (< (setq numoftxt (vl-list-length lstFiles)) 32767)
  (acet-ui-progress "Working: " 32767)
  (acet-ui-progress "Working: " numoftxt)
; (foreach txtfile (vl-directory-files folder "*.txt" 1)
 (foreach txtfile lstFiles
   (cond
     (command "._layer" "_set" "Filename" "")
     (setq ToolStr (afterequal)); Text string
     (setq txt (afterequal) startX (atof (tocomma))
     ); setq
     (command "._layer" "_set" toolstr "")
     (command "_.line" "_none" (setq lstart (list (+ startX shift) startY startZ))
		       "_none" (setq lend (list (+ endX shift) endY endZ)) "")
     (setq toolstr nil)
             p1 lstart
             p2 lend
       ); setq
        (setq ; then
              p3 lstart
              p4 lend
        ); setq
        (command "_.text" "_style" "PART" "_none" "_mc"
                 (mapcar '/ (mapcar '+ (mapcar 'min p1 p2 p3 p4) (mapcar 'max p1 p2 p3 p4)) '(2 2))0 partStr); command
       ); progn
     ); if [in part box]
    ); LINE condition
     (setq txt (afterequal) ptX (atof (tocomma))
     ); setq
     (command "._layer" "_set" toolstr "");;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
    ); POINT condition
     ); setq
     (command "._layer" "_set" toolstr "");;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
     (command "_.arc"
     ); command
    ); ARC condition
     (setq part T ; triggers use of next 2 Line specs to locate part Text
           lineNo 0)
   ); cond
  (command "._zoom" "_w" zoompt1 Zoompt2)
  (command "._mirror" "_w" mirrpt1 mirrpt2 "" midpt3 midpt4 "_y")
  (command "._layer" "_set" "customer" "")
  ); setq
  ; update meter
  (acet-ui-progress -1)
 ); foreach
 ; close meter
 (acet-ui-progress)
); c:pgbar
Sea-Haven
A couple of speed suggestions, I went from 30 mins to 10 mins, to 2 mins max for a task. Took like 5 versions.
If you look at your "(command" in the code when possible replace with entmake function or better is VL-add function, for setting layer  (setvar 'clayer layername) I found "Point" "Text" "Arc" "Zoom" "Line" all command functions.
Insert a 1000 blocks is like 4 seconds.
Using (vla-InsertBlock mspace (vlax-3d-point bpt) blockname 0.001 0.001 1.0 0.0)
I found acet-progress good but complicated, maybe just use (Princ (strcat "\n" filename)) so see something on the command line. It should just scroll if reduced use of Command
Travis.Biddle
Great tips, thank you so much.  I will work on this tomorrow and see how it goes. Thanks again!!
Travis.Biddle
I tried this code and nothing happens.  I am getting "ADS request error"
Moshe-A
@Travis.Biddle ,
the code is yours and you did not post the all stuff  😀
your request this time was progress bar - no?!
here i isolate it and it works at least for me.
"ADS request error" means something is wrong with (acet-ui-progress) function as said the max init value is 32767
make sure you do not have more than that number of files.
Moshe
(defun c:pgbar ()
 (repeat 32767
  ; update meter
 ); foreach
 ; close meter
 (acet-ui-progress)
