Programming Challenge
john.uhden
john.uhden
It is claimed that the sentence "The quick brown fox jumped over the lazy dog." contains at least one of all the letters in the English alphabet.  Case doesn't matter.
Your challenge is to post a function that proves or disproves that claim.  It should take the sentence as a string and return T or nil, e.g.
(defun true? (str)
  (and
    (= (type str) 'STR)
    (vl-yes-they-are-all-there str)
Have fun, OR ELSE!
John F. Uhden
Replies (91)
ВeekeeCZ
T/nil. Not listing missing ones. ignores the case.
(defun vl-yes-they-are-all-there ( str / l)
  (foreach e (vl-string->list (strcase str))
    (and (not (vl-position e l))
	 (< 64 e 91)
	 (setq l (cons e l))))
  (= 2015 (apply '+ l)))
>> (true? "The quick brown fox jumped over the lazy dog.")
>> nil
>> (true? "The quick brown fox jumps over the lazy dog.")
>> T
Kent1Cooper
jumps
Kent Cooper, AIA
Kent1Cooper
(defun AllLetters (str / chr missing)
  (setq chr 64)
  (while (and (not missing) (< chr 90))
    (setq missing (not (vl-string-position (setq chr (1+ chr)) (strcase str))))
  ); while
  (not missing)
Command: (allletters "The quick brown fox jumps over the lazy dog.")
T
Command: (allletters "The quick brown fox jumped over the lazy dog.")
nil
Command: (allletters "Pack my box with five dozen liquor jugs.")
T
Command: (allletters "test")
nil
In a way, it has the same kind of benefit of (cond) compared to a series of (if) functions -- it checks for the presence of letters only until it finds one missing, and then doesn't need to go any further.
Kent Cooper, AIA
john.uhden
@ВeekeeCZ and @Kent1Cooper
I expected that you two would rise to the occasion, BUT
neither of you tested to see if str was a 'STR! 😠
Kent gets credit for remembering the the correct sentence ("jumps" not "jumped") and proving both.
He also gets extra credit for remembering the other famous sentence.
BUT he used an AutoLisp function name as a symbol (chr), but that's because he knew it was okay as long as it was local.
Sorry, BeekeeCZ, but Kent leads so far.
Still hoping to hear from gurus like @Hak_vz, @ronjonp, @pbejse, @dbroad et al.
John F. Uhden
Kent1Cooper
The converse version, checking that each letter is present so far, rather than whether each one is missing:
(defun AllLetters (str / chr# sofar)
  (setq chr# 64 sofar T)
  (while (and sofar (< chr# 90))
    (setq sofar (vl-string-position (setq chr# (1+ chr#)) (strcase str)))
  ); while
  (numberp sofar)
[And I fixed the variable name, but didn't add a check on the (type) of the 'str' argument.]
The (numberp) "wrapper" can be removed if you don't mind the non-nil return being a number, rather than T.
Kent Cooper, AIA
hak_vz
(defun has_all_letters (str / a b c d e dec cnt)
	(cond
		((= (type str) 'STR)
			(setq dec (cdr(vl-sort (vl-string->list (strcase str)) '<)))
			(cond
				((= (length dec) 26)(setq a T) (princ "\nThis sentence has 26 letters - TRUE"))
				(T (princ "\nThis sentence doesn't have 26 letters - FALSE"))
			(cond
				((= (chr (car dec)) "A")(setq b T) (princ "\nFirst alhabetically ordered letter is A - TRUE"))
				((/= (chr (car dec)) "A")(princ "\nFirst alhabetically ordered letter is not A  - FALSE"))
			(cond
				((= (chr (last dec)) "Z")(setq c T) (princ "\nLast alhabetically ordered letter is Z - TRUE"))
				((/= (chr (last dec)) "Z")(princ "\nLast alhabetically ordered letter is not Z  - FALSE"))
			(setq
				d T
				cnt -1
			(while (and (and d)(< (setq cnt (1+ cnt))(1- (length dec))))
				(if (/= (- (nth (1+ cnt) dec)(nth cnt dec)) 1) (setq d nil))
			(cond
				((and d)(princ "\nAll letters in this sentence are in sequence - TRUE"))
				(T (princ "\nNot all letters in this sentence are in sequence - FALSE"))
			(setq e (apply 'and (list a b c d)))
			(cond
				 ((not e)(princ "\n\nAll letters from English alphabet are not present - final result:_______ FALSE"))
				 ((and e)(princ "\n\nAll letters from English alphabet are here - final result: _______TRUE"))
		(T (princ "\nFunction argument is not a string!"))
(princ)
Command: (setq str "The quick brown fox jumped over the lazy dog")
Command: (has_all_letters str)
Command: (setq str "The quick brown fox jumps over the lazy dog")
Miljenko Hatlak
Kent1Cooper
If you want it to tell you which letter(s) is/are missing:
  (setq chr# 64 missing "")
  (while (< chr# 90)
    (if (not (vl-string-position (setq chr# (1+ chr#)) (strcase str)))
      (setq missing (strcat missing (chr chr#)))
    ); if
  ); while
  (prompt
    (if (= missing "")
      "\nAll letters present." ; then
      (strcat "\nMissing letter(s): " missing "."); else
    ); if
  ); prompt
  (princ)
Kent Cooper, AIA
dbroad
Since you're calling the test function from another function that already tests whether or not the argument is a string, that hardly seems necessary.
(defun test (str / lst i)
(setq lst (vl-string->list (strcase str)))
(setq i 65)
(while (and (< i 91)
	    (vl-position i lst))
  (setq i (1+ i)))
(= i 91)
You could also do a precheck.
(>=(length lst) 26))
Architect, Registered NC, VA, SC, & GA.
john.uhden
That's very close to my first attempt...
(defun @Anonymous? (str / n ok)
  (and
    (= (type str) 'STR)
    (setq str (vl-string->list (strcase str)) n 64 ok T)
    (while (and ok (< n 90))
      (setq ok (vl-position (setq n (1+ n)) str))
    (boundp (quote ok))
 so I guess your 2nd version is an improvement. 😁
Here is my 2nd attempt:
(defun istrue (str / chrs)
  (and
    (= (type str) 'STR)
    (setq chrs '(90))
    (repeat (- 90 65)(setq chrs (cons (1- (car chrs)) chrs)))
    (not (vl-position nil (mapcar '(lambda (#)(vl-position # (vl-string->list (strcase str)))) chrs)))
;; I tried using...
;; (vl-every 'vl-position chrs (vl-string->list (strcase str)))
;; but I've never figured out how to use vl-every
John F. Uhden
john.uhden
Yo, Hak,
I didn't require that the sentence be 26 characters long, nor start with A and end with Z, nor be all caps, nor that the letters have to be in any order.
But I admire your perspicacity, much like Abbie on NCIS.
John F. Uhden
john.uhden
NICE, @dbroad.
So simple.
You just jumped into the lead! 👍
John F. Uhden
hak_vz
@john.uhden wrote:
Yo, Hak,
a) 26 letters in English alphabet.  Sentence should have at least 26 characters
b) I sort all letters in a list from smallest to largest and have decided to use uppercase
c) But you asked that all letters are here, so in sorted list first is A last is Z
To resolve case with more than 26 letters in a sentence unique filtering is needed.
So my algorithm can be summed up:
Take all letters in sentence, convert to integers and use unique filter
Convert to uppercase or lowercase for continuity and re move space
Test is sorted list is in sequence
Code was made on the fly so errors are here
Miljenko Hatlak
john.uhden
@ВeekeeCZ
Okay, okay, PROTEST accepted.
1.  You did not use a protected name as a symbol. - TRUE 😊
2.  Other than the input argument, you used only one local. - TRUE 😀
3.  You actually named your function with the silly named I posted. - TRUE 😁
4.  Your function is as good as either of Kent's. - TRUE 😌
5.  Your function is as simple and good as Doug's - FALSE 😢
John F. Uhden
john.uhden
@hak_vz
It hurts me to say this to someone of your imminent eminent stature, but
take another look at Doug's.
John F. Uhden
doaiena
Here is a quick one from me:
(defun test (str)
(= (length (vl-sort (vl-remove-if-not '(lambda (x) (and (> x 64) (< x 91))) (vl-string->list (strcase str))) '<)) 26)
john.uhden
@doaiena
Very nice!
Slight improvement:
(defun test (str)                                    ; ↓↓↓↓↓↓↓↓
  (= (length (vl-sort (vl-remove-if-not '(lambda (x) (< 64 x 91))
 Pluses:
1.  You knew (or stumbled on the fact) that vl-sort removes duplicates. 🙂
2.  Zero locals other than input argument. 😀
3.  Very short and sweet. 😃
4.  Very few seem to care about checking if str is a 'STR. 🤔
@dbroad ,
You've got some serious competition here (with my assistance).
Of course I haven't checked any of them for speed, but like how many times are you going to repeat this?
John F. Uhden
doaiena
@dbroad's function is hard to beat. vl-position is lightning fast and is going to be called 26 times in he worst case scenario. Definitely the best solution if you ask me.
john.uhden
@doaiena,
Well, I didn't ask. I guess I should have.🤐
I'm waiting for any late entries.
John F. Uhden
dbroad
@doaiena , Your function is a witty one liner.  I like that it doesn't need any local vars.  They're both very fast. Benchmarking it depends on the program used and the order of the functions tested. When tested individually with Rob Bell's first bench version, yours appears slower but I doubt that matters much since both are almost the same time. If there were thousands of strings to test, I would imagine that something like this would be faster than either although this would be slower unless you had the perfect string.
  (setq i 65)
  (and (>= (length lst) 26)
       (while (and (< i 91) (vl-position i lst)) (setq i (1+ i)))
       (= i 91)
This would immediately eliminate strings shorter than 26 characters before looping.
In college, I found, when writing in APL, that putting too much in a single line was really fun until I started having to debug my work months later. Each greek character could do an immense amount of calculation and I was stringing hundreds of them side by side to do hundreds of lines of Fortran in a single line.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
