Problems with OpenDCL and AutoCAD 2024
cheungyl886
cheungyl886
Community Visitor
Community Visitor
I regularly use the Customize tool to prepare drawings for my daily work. Previously, it worked fine, and the dialog box would pop up as expected. However, after returning from the holiday, the customize command no longer works, and the dialog box fails to appear.
When I run the command, the following appears on the command line:
"Command: (load "scale2")
OpenDCL Runtime [9.2.4.1] loaded
_OPENDCL
C:SCALE2-SCX
Command:
Command: scale2-scx
Command:"
I have installed the latest version of OpenDCL, but the issue persists. Any suggestions on how to resolve this?
Thanks!
pendean
Community Legend
Community Legend
@cheungyl886 try asking in their dedicated user forums
https://opendcl.com/forum/index.php
Sea-Haven
Try another program that uses opendcl as a check. I dont use Opendcl Make a test program that just displays the dcl in case its a problem with the lisp part of code.
