Problem with vlisp for layer names in Chinese
Rockit_for_Revit
Message 1 of 12
Rockit_for_Revit
Hello, I tried to run a command on a dwg that has layer names in Chinese e.g: JOINERY-家具定制
The following lisp does not return the correct layer rather JOINERY-???????
(vlax-get-property obj 'Layer)
the following does not work either:
(vlax-put-property obj 'Layer "JOINERY-家具定制")
I had to do the old way eg:
(EntMod Entg 8 "JOINERY-家具定制")
I think its a bug in vlisp.
Regards
David
Replies (11)
Message 2 of 12
paullimapa
the following sequence works renaming layer from "1" to "JOINERY-家具定制":
(setq obj (vlax-ename->vla-object (tblobjname"layer""1")))
(vla-put-name obj "JOINERY-家具定制")
Paul Li
IT Specialist
@The Office
Message 3 of 12
paullimapa
the following works to add layer "JOINERY-家具定制":
(vla-Add (vla-Get-Layers (vla-Get-ActiveDocument (vlax-Get-Acad-Object))) "JOINERY-家具定制"))
Paul Li
IT Specialist
@The Office
Message 4 of 12
paullimapa
those also only show up as ???? in Autocad 2020. But starting 2021 that's been corrected.
Paul Li
IT Specialist
@The Office
Message 5 of 12
Rockit_for_Revit
Thank you, I'm using AutoCAD 2025.
The issues are with vlax-get-property and vlax-put-property
Message 6 of 12
Sea-Haven
Worked Bricscad V24.
Message 7 of 12
paullimapa
Don't use:
But use this:
vlax-get-property obj 'Name)
Likewise, don't use:
But use this:
(vlax-put-property obj 'Name "JOINERY-家具定制")
So the following code sequence will create a list of layers in 2025 and the Chinese characters do show up in the returned list:
(setq la_doc (vla-get-ActiveDocument (vlax-get-acad-object)) ; get dwg obj
      la_lyr (vlax-get-property la_doc 'layers) ;; Get the collection of layers in the document
      lst nil
(defun layer-lst (theLayer)(setq lst(append lst (list(vlax-get-property theLayer 'Name)))))
(vlax-map-collection la_lyr 'layer-lst) ; create layer name list
(vl-sort lst '<) ; sort layer name list
Likewise you can rename a layer named "1" to a name with the Chinese characters:
(defun layer-ren (theLayer)(if (eq "1" (vlax-get-property theLayer 'Name))(vlax-put-property theLayer 'Name "JOINERY-家具定制")))
(vlax-map-collection la_lyr 'layer-ren)
Paul Li
IT Specialist
@The Office
Message 8 of 12
paullimapa
also make sure you've installed the 2025.1.1 update
Paul Li
IT Specialist
@The Office
Message 9 of 12
Rockit_for_Revit
I'm mainly after getting the layer of an existing element and changing its layer, rather than dealing with the layers themselves.
When I dump the element I get ?? under Layer:
; Property values:
; Application (RO) = #<VLA-OBJECT IAcadApplication 00007ff7b5cfa068>
; Area (RO) = 2.14614e+07
; Closed = -1
; ConstantWidth = 0.0
; Coordinate = ...Indexed contents not shown...
; Coordinates = (381813.0 -120502.0 385863.0 -120502.0 385863.0 -125801.0 ... )
; Document (RO) = #<VLA-OBJECT IAcadDocument 000002b583c38068>
; Elevation = 0.0
; EntityTransparency = "ByLayer"
; Handle (RO) = "C53DF54"
; HasExtensionDictionary (RO) = 0
; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000002f6a6cd6c58>
; Layer = "EQUIPMENT-??"
; Length (RO) = 18698.5
Message 10 of 12
paullimapa
As I mentioned I only see those ??? with the older 2020 version.
And I don't see that problem in my 2025.1
Paul Li
IT Specialist
@The Office
Message 11 of 12
Rockit_for_Revit
I have 2025.1.1
Attached is a sample of the dwg
Message 12 of 12
paullimapa
I still have no problems listing the layers with the chinese characters using vlisp.
Perhaps it's time for you to submit a trouble ticket through your management portal.
Also include your Windows OS version. I'm still on Windows 10.
Paul Li
IT Specialist
@The Office
