Problem with spaces in script file
danglar
danglar
I have a program for add file prefix "Xref-" and suffix as current date
and open modified XREF file with close and delete previous file (see attached lisp).
Program working properly until you have file name with spaces between words
(example: pump station.dwg) or you have a path with spaces between words
(example: c:\Pump station\example.dwg)
Can somebody fix it?
Kent1Cooper
I believe if you enclose them in double-quotes, all will be well:
"pump station.dwg"
and
"c:\Pump station\example.dwg"
Kent Cooper, AIA
danglar
Path and name of file here is a variable (not constant) so I need to do it programmaticaly somehow...
kerry_w_brown
http://www.theswamp.org/index.php?topic=50551.msg556774#msg556774
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
