Problem using GETFILED
Message 1 of 22
With AutoCAD 14, if I type the following at the command prompt:
(setq a (getfiled "Select a Drawing file" "" "dwg" 8))
I get the dialog box to select the file. As long as I do not change the
directory or folder
AutoCAD returns the filename that I selected with no path.
If I do the exact same thing in AutoCAD 2000, I get the full path.
How can I get the filename only?
Dennis
Replies (21)
Message 2 of 22
You can use VL-FILENAME-BASE to strip the directory from a filename. It also
strips the extension though. If that's a problem, you can use something like
this to keep the extension (assuming the return value from GETFILED is
stored in the variable fn):
(substr fn (+ (strlen (vl-filename-directory fn)) 2))
Or if you have the express tools, just use ACET-FILENAME-PATH-REMOVE
Get free software and more at:
http://msnhomepages.talkcity.com/protectionfault/foquendo
"Dennis S. Nunes" wrote in message
news:[email protected]...
> directory or folder
> Thanks
> Dennis
Message 3 of 22
Dennis,
I'm not sure what you have in mind to do with the filename, but here are
some options that might give you some ideas. They tend to be a bit long,
though.
Dave D
;For drawing name only in the current drawing directory, but is
;incorrect for any other directory with a different length name.
(defun c:getfil1 ()
(if (setq a (getfiled "Select a Drawing file" "" "dwg" 8))
(progn
(setq l (1+ (strlen (getvar "dwgprefix"))))
(setq a (substr a l))
(princ a)
(prompt "\nYou cancelled. ")
(princ)
;For drawing name only in any drawing directory:
(defun c:getfil2 ()
(progn
(setq l (strlen a) b x)
(while (/= b "\\")
(setq l (1- l))
(setq b (substr a l 1))
(setq a (substr a (1+ l)))
(princ a)
(princ)
;For R14 behavior with GetFileD:
(defun c:getfil3 ()
(progn
(while (/= b "\\")
(setq l (1- l))
(if (wcmatch (substr a 1 l) (getvar "dwgprefix"))
(princ a)
(princ)
Dennis S. Nunes wrote in article
<[email protected]>...
> directory or folder
> Thanks
> Dennis
Message 4 of 22
(cadr (fnsplitl a))
> directory or folder
> Thanks
> Dennis
| Byron Blattel
| CADwerx---Applications for AutoCAD
| e-mail: [email protected]
Message 5 of 22
Frank,
Where did you come up with ACET-FILENAME-PATH-REMOVE, and how is it used?
It isn't in the listing that I have.
Dave D
Frank Oquendo wrote in article
also
like
Message 6 of 22
(defun strip-path (str)
(if (wcmatch str "*[\\/]*") (strip-path (substr str 2)) str)
e.g.
(strip-path "c:\\acad\\sample\\yadayadayada\\drawing.dwg")
returns "drawing.dwg"
__________________________________
Michael Puckett
[email protected]
> Not < an Autodesk hall monitor.
Imagination makes all things possible.
directory or folder
Dennis
Message 7 of 22
It shows up in my APROPOS window when I search on ACET. You just feed it the
full path and it returns only the filename: (acet-filename-path-remove
(findfile "acad.exe")) yields "acad.exe" whereas findfile returns the full
path. I'm using ACETUTIL.ARX ver 1.35. You can check your version by calling
(acet-util-ver)
"David Doane" wrote in message
news:01bf7002$9fb8d800$1d57d2d0@lms-1...
> Frank,
> Dave D
> also
> like
Message 8 of 22
That splits a path into three components: the directory, the file base and
the extension. I don't think that would help too much in this particualt
case without concatenating the second and third items in the list.
"Byron Blattel" wrote in message
> (cadr (fnsplitl a))
> > directory or folder
> > Thanks
> > Dennis
> | Byron Blattel
Message 9 of 22
I believe he said he wanted the filename only, not the filename with
extension 🙂
> > > Thanks
> > > Dennis
Message 10 of 22
No it returns the filename with extension. I just took his request
literally.
(strcat (cadr (fnsplitl a)) (caddr (fnsplitl a)))
The point was that there is an AutoLISP function available for this
(fnsplitl) at least since R14.
> Was that the behavior of GETFILED prior to A2K? I thought it returned a
> "Whatever".3 filename if you selected from the initial directory.
> > extension 🙂
> and
> > > > > Thanks
> > > > > Dennis
| Byron Blattel
Message 11 of 22
> extension 🙂
and
> > > > Thanks
> > > > Dennis
Message 12 of 22
Thanks Frank, the (substr fn (+ (strlen (vl-filename-directory fn)) 2))
worked just fine!
Frank Oquendo wrote in message
also
like
> > directory or folder
> > Thanks
> > Dennis
Message 13 of 22
No problem. Glad to help.
> worked just fine!
> also
> like
the
> > > directory or folder
> > > Thanks
> > > Dennis
Message 14 of 22
Where did you find that function anyway? It shows up in the Apropos window
but there's no documentation.
> literally.
> > > extension 🙂
base
> > and
particualt
> > > > > > Thanks
> > > > > > Dennis
> | Byron Blattel
Message 15 of 22
How did you know about that one!???
I search A2K help and found it only as a reference under atomlist-family -
in an example. Great function!
Mike
> literally.
> > > extension 🙂
base
> > and
particualt
> > > > > > Thanks
> > > > > > Dennis
> | Byron Blattel
Message 16 of 22
Don't recall, might have been Owen's site or maybe just playing around
with (atoms-family) 🙂
| Byron Blattel
Message 17 of 22
This function is exported from 'acetutil.fas', not 'acetutil.arx'.
We've added a filename manipulation class to our ARX libraries, so we'll be
moving most of the '(acet-filename-...)' functions to 'acetutil.arx' (and
I'll update the documentation).
Frank Whaley
Autodesk, Inc.
[email protected]
http://www.autodesk.com/expresstools
Express Tools - Your wish is our (command ...)
Message 18 of 22
Well, ain't you the hotsy-totsy?
Like I've said before, if you're as tight with everything else as you are
with your code, when you break wind only the dogs can hear it.
So using your little tech-ni-que, and exhibit might look like:
;;;For drawing name only in any drawing directory:
(defun c:getfila ()
(progn
(while (wcmatch a "*[\\/]*") (setq a (substr a 2)))
(princ a)
(prompt "\nYou canceled. ")
(princ)
;;;For R14 behavior with GetFileD:
(defun c:getfilb ()
(progn
(if (wcmatch a (strcat (getvar "dwgprefix")"*"))
(princ a)
(princ)
Of course you will probably cut that by two-thirds as well.
I'm goin' back to sleep .......
Dave D
Michael Puckett wrote in article
> e.g.
> Michael Puckett
> [email protected]
> directory or folder
> Thanks
> Dennis
Message 19 of 22
I have the same version, but what the heck is an APROPOS window??
It does work as you described. Thanks for the tip.
Dave D
the
full
calling
> (acet-util-ver)
> > Frank,
used?
> > Dave D
Message 20 of 22
OK. Found the APROPOS window. Never use Vlide. I just saw another post
concerning it and took a look-see.
Dave
the
full
calling
> (acet-util-ver)
> > Frank,
used?
> > Dave D
