Print to File autocad command lsp
KimBrunz
KimBrunz
Does someone have a function that prints out all the autolisp/vlisp commands to file?  The lsp command will print to screen but how do you get that output to file?
Thanks for any help
Windows 10 Pro 64 bit
Currently PDS 2018 but testing alternatives
i7 3770k 16 Gb RAM GTX 1070
Would you describe with some more details what you would like to achieve ? I think that I can help you.
KimBrunz
If you type “lsp” at the command line, the prompt is “commands/functions/variables”. Functions gives you a list of the autolisp/vlisp command set, ie. atom, car, eq, print, etc. I would like to print out the command set to file to use in an editor.  The output to screen only saves a few pages, ie. Not the whole set.
Thanks, Kim
marko_ribar
Try using commands : LOGFILEON and LOGFILEOFF... So firstly LOGFILEON, then LSP, ACAD prints to screen and log file and after finish LOGFILEOFF... Then search for *.log file - look for sysvar LOGFILENAME to see where is it stored on HD...
Marko Ribar, d.i.a. (graduated engineer of architecture)
KimBrunz
Thanks Marko, I was creating the output and never thought about it being saved to the LOGFILE.  Clearly a "DUH" moment.
Kim
john.uhden
I posted this some time back, but here it is again...
LISTFUNS.lsp which looks like...
Command: LF
LISTFUNS v15.01 (c)1994-2001, John F. Uhden, Cadlantic
Function name(s)/<*>: *
Variable Type...
Exsubr/eXrxsubr/File/Int/List/eName/paGetb/Pickset/Real/Safearray/sTr/sUbr/sYm/
vAriant/Vla-object/*, <*>:
   [which will return all the matches here]
Write to file? Append/Overwrite/<No>:
John F. Uhden
