Print Background with Publish command in AUTOCAD OEM 2019 doesn't work
BetaCADsrl
Message 1 of 1
BetaCADsrl
With Autocad OEM 2019, if you launch the publish command with the background print option checked, the print never ends (and never print anything). With the option unchecked the publish command print all the needed files in a short time.
ADDITIONAL NOTES:This problem was the same also in OEM 2016 and 2018 (AutoCAD full always works)
is it a bug or there's something I can do to make it works?
Replies (0)
