Possible to write a lisp for layer on whole viewports.
smallƑish
Message 1 of 11
smallƑish
In my drawing have 20+ layouts each has multiple viewports. All viewports layer properties are different...Instead of selecting each model space of each viewports,  selecting all layers, making all layer on, non freeze, enable print etc...... Can we do it with any lisp.?
Replies (10)
Message 2 of 11
paullimapa
What you are referring to has nothing to do with Pspace Vports.
Layers turned off/frozen/noplot can be turned on/thawed/plot once by using this sequence of commands regardless of Model or Layout:
(command"_.Layer""_T""*""_On""*""_P""_P""*""")
Paul Li
IT Specialist
@The Office
Message 3 of 11
komondormrex
you are wrong. paperspace viewports have independent layers settings, which may differ from those of modelspace.
Message 4 of 11
paullimapa
Papace Vports do have layer settings. But the only setting that comes close to what your OP described is called freeze/thaw but not on/off or plot enabled or disabled.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/AutoC...
Paul Li
IT Specialist
@The Office
Message 5 of 11
paullimapa
FYI: Here’s a code to vplayer thaw all layers in all layouts written over a decade ago:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-file-to-thaw-all-layers-frozen-...
Paul Li
IT Specialist
@The Office
Message 6 of 11
komondormrex
Message 7 of 11
paullimapa
\Now those are the correct terminology.
These can all be done by slightly modifying the code I posted earlier like this:
(setq clayout (getvar 'ctab))
(foreach layout (layoutlist)
  (setvar 'ctab layout)
;  (command "_.vplayer" "_thaw" "*" "_all" "")
  (command "_.vplayer" "_M" "_A" "*" "_all" "")
(setvar 'ctab clayout)
Also, read up on VPLAYEROVERRIDESMODE setting:
Without A Net: Reset Layer Viewport Overrides from VPLAYER (typepad.com)
Paul Li
IT Specialist
@The Office
Message 8 of 11
smallƑish
frozen layers are still as it is in layout 1 . I don't know what's wrong
Message 9 of 11
paullimapa
Post your dwg here so I can take a look
Paul Li
IT Specialist
@The Office
Message 10 of 11
smallƑish
In the dwg file, there are 9 layouts. each even number layouts Layer VP-SET will be disabled for plotting,
either layer is freeze, off, print disable, etc.
I have made this for your easy understanding.
please try your code.
Message 11 of 11
paullimapa
apparently the override setting applies to all the VP Columns except for VP Freeze column
so I've modified the code and called it VPO...give this a try:
(defun c:vpo (/ clayout)
;  (command "_.vplayer" "_M" "_A" "*" "_all" "")
  (command "_.vplayer" "_T" "*" "_all" "_M" "_A" "*" "_all" "")
 (setvar 'ctab clayout)(princ)
) ; defun
Paul Li
IT Specialist
@The Office
