Message 1 of 12
Populate room name and id if is in block range. Also populate value same values form selected blocks.
Afternoon and Happy Friday
Aha Another idea.
We have drawing from architects or consultant with room names and ID. We received a lot drawings with a lot mess as people they not interested to work more efficient or consistent. It takes so much time to setup things.
Room names and ID can appear in MTEXT or TEXT. Until now we use dynamic block with attributes (see below in pictures). We draw block to each room and manually adding names. It would be helpful is possible to automacly pick up text if is block range and populate two attributes.
In this situation we have MText but it would nice if is would be more flexible:
- Chose if is MText, Text or Both
- Able to separate word by any symbol (or string). e.g. Laundry - D1.
- In some drawing are two texts (also it can MText or Text) which Above is Room Name and Below is Room ID.
- Where is places we you have to draw more block with same room name. e.g. Some rooms have L Shape or other shapes. In this situation it would nice to populated selected blocks with same Room and ID attribute values.
Please example below.
Robertas
