Polylines lengths layer wise from different closed polygons:
I got a lisp code that can summarize polyline lengths Layer wise, but can’t summarize the polyline lengths from closed polygones separately. Suppose we have Zone-1, Zone-2, Zone-3 as closed polygons in their respective layers and then output lisp code should generate the polyline lengths inside the closed polygons as shown in attached Snapshot and cad file.
(defun c:mlen (/ m ss clist temp xls sort combine mlen4_1)
  (defun sort (lst predicate)
    (mapcar '(lambda (x) (nth x lst)) (vl-sort-i lst predicate))
  (defun combine (inlist is-greater is-equal / sorted current result)
    (setq sorted (sort inlist is-greater))
    (setq current (list (car sorted)))
    (foreach item (cdr sorted)
      (if (apply is-equal (list item (car current)))
  (setq current (cons item current))
  (progn
    (setq result (cons current result))
    (setq current (list item))
(defun xls ( Data-list header Colhide Name_list / *aplexcel* *books-colection* Currsep
*excell-cells* *new-book* *sheet#1* *sheet-collection* col iz_listo row cell cols)
(defun Letter (N / Res TMP)(setq Res "")(while (> N 0)(setq TMP (rem N 26)
  TMP (if (zerop TMP)(setq N (1- N) TMP 26) TMP)
  Res (strcat (chr (+ 64 TMP)) Res)  N   (/ N 26))) Res)
(if (null Name_list)(setq Name_list ""))
  (setq  *AplExcel*     (vlax-get-or-create-object "Excel.Application"))
  (if (setq *New-Book*  (vlax-get-property *AplExcel* "ActiveWorkbook"))
    (setq *Books-Colection*  (vlax-get-property *AplExcel* "Workbooks")
          *Sheet-Collection* (vlax-get-property *New-Book* "Sheets")
               *Sheet#1*     (vlax-invoke-method *Sheet-Collection* "Add"))
              *New-Book*     (vlax-invoke-method *Books-Colection* "Add")
               *Sheet#1*     (vlax-get-property *Sheet-Collection* "Item" 1)))
(setq *excell-cells*     (vlax-get-property *Sheet#1* "Cells"))
(setq Name_list (if (= Name_list "")
                  (vl-filename-base(getvar "DWGNAME"))
                  (strcat (vl-filename-base(getvar "DWGNAME")) "&" Name_list))
   col 0 cols nil)
(if (> (strlen Name_list) 26)
(setq Name_list (strcat (substr Name_list 1 10) "..." (substr Name_list (- (strlen Name_list) 13) 14))))
(vlax-for sh *Sheet-Collection* (setq cols (cons (strcase(vlax-get-property sh 'Name)) cols)))
(setq row Name_list)
(while (member (strcase row) cols)(setq row (strcat Name_list " (" (itoa(setq col (1+ col)))")")))
(setq Name_list row)
(vlax-put-property *Sheet#1* 'Name Name_list)
(setq Currsep (vlax-get-property *AplExcel* "UseSystemSeparators"))
(vlax-put-property *AplExcel* "UseSystemSeparators" :vlax-false) ;_не использовать системные установки
(vlax-put-property *AplExcel* "DecimalSeparator" ".")            ;_разделитель дробной и целой части
(vlax-put-property *AplExcel* "ThousandsSeparator" " ")          ;_разделитель тысячей
(vla-put-visible *AplExcel* :vlax-true)(setq row 1 col 1)
(if (null header)(setq header '("X" "Y" "Z")))
(repeat (length header)(vlax-put-property *excell-cells* "Item" row col
(vl-princ-to-string (nth (1- col) header)))(setq col (1+ col)))(setq  row 2 col 1)
(repeat (length Data-list)(setq iz_listo (car Data-list))(repeat (length iz_listo)
(vlax-put-property *excell-cells* "Item" row col (vl-princ-to-string (car iz_listo)))
(setq iz_listo (cdr iz_listo) col (1+ col)))(setq Data-list (cdr Data-list))(setq col 1 row (1+ row)))
(setq col (1+(length header)) row (1+ row))
(setq cell (vlax-variant-value (vlax-invoke-method *Sheet#1* "Evaluate"
    (strcat "A1:" (letter col)(itoa row))))) ;_ end of setq
(setq cols (vlax-get-property cell  'Columns))
(vlax-invoke-method cols 'Autofit)
(vlax-release-object cols)(vlax-release-object cell)
(foreach item ColHide (if (numberp item)(setq item (letter item)))
    (strcat item "1:" item "1"))))
(vlax-put-property cols 'hidden 1)
(vlax-release-object cols)(vlax-release-object cell))
(vlax-put-property *AplExcel* "UseSystemSeparators" Currsep)
(mapcar 'vlax-release-object (list *excell-cells* *Sheet#1* *Sheet-Collection* *New-Book* *Books-Colection*
*AplExcel*))(setq *AplExcel* nil)(gc)(gc)(princ))
  (defun mlen4_1 (lst / sum_len)
    (setq sum_len 0)
    (foreach item (mapcar 'car lst)
      (setq
  sum_len  (+ sum_len
       (if (vlax-property-available-p item 'length)
         (vla-get-length item)
         (cond
        (strcase (vla-get-objectname item) t)
        "acdbarc"
      ) ;_  =
      (vla-get-arclength item)
        "acbcircle"
      ) ;_  =
      (* pi 2.0 (vla-get-radius item))
           (t 0.0)
         ) ;_  cond
       ) ;_  if
    ) ;_  +
    (if  (not (zerop sum_len))
      (princ
  (strcat "\n\t" (cdar lst) " = " (rtos (* sum_len m) 2 4))
    (list (cdar lst)(rtos (* sum_len m) 2 4))
  (vl-load-com)
  (if (null *M*)(setq *M* 1))
  (initget 6)
  (and
    (princ "\nEnter scale factor <")
    (princ *M*)(princ ">: ")
    (or (setq m (getreal))
   (setq m *M*)
    (setq *M* m)
    (setq ss (ssget "_:L"))
    (setq ss (mapcar
         (function vlax-ename->vla-object)
         (vl-remove-if
     (function listp)
     (mapcar
       (function cadr)
       (ssnamex ss)
     ) ;_  mapcar
         ) ;_ vl-remove-if
         (setq temp (cons (cons x (vla-get-Layer x)) temp))
      ss
    (setq clist  (combine temp
       '(lambda (a b)
          (> (cdr a) (cdr b))
       '(lambda (a b)
          (eq (cdr a) (cdr b))
    (princ
      "\n\n  The total length of all line primitives by layers:"
    (setq temp (mapcar 'mlen4_1 clist))
    (xls temp '("Layer" "Length") nil "mlen41")
  (princ)
) ;_  defun
I need polyline lengths as shown in attached image and cad file.
T.Brahmanandam
pbejse
Can you at least give credit or include a link on your post where you get the code your posting here  tnvsb
List total Polyline lengths according to Layer
EDIT: The defined "ZONES" on your sample is a simple rectangular shape,  does that represent a similar drawing where you are planning to run the program?
You are doing it again buddy
Ya, Surely.
I got this code from below link:
http://forums.augi.com/showthread.php?60131-List-total-Polyline-lengths-according-to-Layer
T.Brahmanandam
Kent1Cooper
You can have it not include the lengths of closed Polylines.  And you don't need to get the length in different ways for different entity types -- there's a generic method that will get it for anything with linearity.
(if (not (and (vlax-curve-isClosed item) (= (vla-get-ObjectName item) "AcDbPolyline"))) (setq sum_len
sum_len (vlax-curve-getDistAtParam item (vlax-curve-getEndParam item))
); + ); setq ); if ); foreach ....
Kent Cooper, AIA
DearSir,
Could you please include this code in entire lisp and then please reply. i replaced the original code with your input but unable to get the result. Please help me Sir.
dbhunia
Hi
I made change in a line in your coding, now with this code you will get the your required CABLE information only. But with your code you have to select each zone separately.
Otherwise if you select the total drawing then your code can not decide the zone separately.
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Thank you Sir.
