Polylines Joining For No Reason
mgorecki
Message 1 of 21
mgorecki
I have never run into this before, so I'm at a loss for why it's happening.  I'm using AutoCad 2018 Vanilla in Windows.
My code adds lwpolylines on a layer at a certain width (50.0).  It's like a grid with horizontal and vertical lwpolylines.
Then it turns off that layer and turns on, and sets, another layer.  It creates more lwpolylines with a different width (280) at the exact same coordinates.
When it's done running, the lwpolylines on the first layer are gone.  When I check the lwpolylines on the second layer, they have both widths.
This is a listing of one of the lwpolylines:
LWPOLYLINE Layer: "SOLDERMASK_BOTTOM"
Space: Model space
Handle = 1a21e
Closed
area 0.0000
perimeter 113600.0000
at point X=-35500.0000 Y=28400.0000 Z= 0.0000
starting width 50.0000
ending width 50.0000
at point X=-35500.0000 Y=-28400.0000 Z= 0.0000
starting width 280.0000
ending width 280.0000
This is the code used to create the lwpolylines:
(defun CreateLWPoly (plPntList plWidth openORclose)
 (entmake (append (list (cons 0 "LWPOLYLINE")
                        (cons 100 "AcDbEntity")
                        (cons 100 "AcDbPolyline")
                        (cons 90 (length plPntList))
                        (cons 70 openORclose) ;closed(1) or open(0)
                        (cons 43 plWidth)
                  (mapcar (function (lambda (p) (cons 10 p))) plPntList)
If anyone has an idea why this happens, I'd appreciate it if you let me know.  Thanks.
Replies (20)
Message 21 of 21
Sea-Haven
A 2D lwpolyline has a Elevation setting ie Z (38 . 0.0) so could add that maybe at like 1000.0
The other suggestion is maybe do a regen every 100 etc.
