Polyline Total AutoLisp
Hi
Can someone do the coding for this if this is possible
. Thank you
ВeekeeCZ
Post this as dwg.
What is that program about? This might be an issue to incorporate.
Also, creating such a table can be laborious.
john.uhden
My very old LABEL_IT program could add labels for bearing, distance, and arc data. even to objects nested in a block or xref with an option to use leaders or create tags and produce a curve/line table.  Yeah, you can do entire polylines or just selected segments, and reverse the direction which is indicated by familiar looking glyphs.  But the table was pre-tables, just lines and text in an anonymous block.  I think I'll update it.  I am sick of the C3D method of labeling where you are severely limited in moving and/or editing the labels unless you explode them twice, which is obviously contrary to Autodesk's view of how our plans should look.  No offense to the masters of the universe, but I am in favor of home rule.  We're gonna start CAD meetings with the principals in January.  They actually seem to respect my views and experience, so maybe we'll make a step forward by taking a step back.  I will let you know.
John F. Uhden
Hi, Sorry I don't know that there are sections here. For this one as you can see I am asking if someone can make lisp code for this following the sequence shown in the photos (Only if its possible)
Hi, I don't really get what you mean, but its a great help if you can do the lisp coding following the sequence shown.
