polyline grade label lisp
trumankiko
trumankiko
can someone share a lisp that auto labels a polyline with it's grade (in percent)? thanks!
TomBeauford
As a lightweight polyline only has one elevation the grade would always be zero. Can you describe what you're looking for? Is this for a Civil Profile sheet?
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Sea-Haven
If civil profile then does it have Horizontal and Vertical scales ?
john.uhden
@trumankiko ,
You must explain whether you want to label a 3Dpolyline in plan view or a 2Dpolyline (LW) in profile.  And yes, if the latter, you must reveal both the horizontal and vertical scales.  Customarily the vertical scale is 1/10th of the horizontal scale, or exaggerated by 10X.
John F. Uhden
