POLYLINE BORDER TO VIEWPORT BORDER ==== PL4VIEWPORT
rolisonfelipe
rolisonfelipe
How to make the red line that is in the model as the edge of the viewport in layout01, is there any command?
If it doesn't exist, is there a lisp that can select the red boundary in the model and launch it as a viewport for the layout.
Thank you to everyone who can contribute
That would be an example of what it would look like
Sea-Haven
Something like this, make the rectang to suit then makes the layout.
rolisonfelipe
generate the rectangle and place it in the viewport, that's easy!
What I wanted was to exclude everything that is outside the polyline with the help of the viewport becoming the limit with the red line
daniel_cadext
MVIEW?
https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-5272B8FC-88FD-4B58-BC7C-A32C71AA22C2
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Kent1Cooper
MVIEW re-scales what you see of Model space through it -- you would have to say how easy it would be to compensate for that.  IMAGECLIP works quite well [with the boundary closed] for other kinds of images:
but for some reason doesn't like the Geomap Image.  Can you convert that to a .jpg or something?
Kent Cooper, AIA
