Polar Stretch and base point of a dynamic block
Hi
i created a polar stretch action on a polyline which is on base point. while trying to move the block the polar stretch grip is selected first. i tried to send the grip to the back, but no use.
can anyone give me a solution.
Moshe-A
@Anonymous hi,
if your object is to insert HC blocks in the center of MH block and spin them around? then this is my remarks:
1. go to block editor
2. delete the polar action and parameter
3. the base point is not in place (move all from left end to 0,0)
4. insert the polar param from 0,0 to the right
5. insert stretch polar action selection set to include the head of the block (e.g the right side)
6. close block editor (and save)
7. back in drawing delete the old HC blocks and insert new.
moshe
I found the problem.
I was using polar stretch with 2 grips. Changed the grips to 1. The grip at the base point was removed so it works well.
