point on the block intersecting on the vertical to point
diegolopezsilanes
diegolopezsilanes
Hello, I am trying to automate the dimensioning process and I would like to find the way you place the dimensions between the block and the rectangles of the attached documents as shown, the dims have to dimension the vertical between the rectangles and the red block at its shorter end .
the prooblem Im having is to find the point on the block intersecting on the vertical to the closest  rectangle point to place the dimensions.
Kent1Cooper
Use APParent-intersection object snap [read about it in Help].
Kent Cooper, AIA
john.uhden
Can we really automate an apparent intersection?
John F. Uhden
