plot pdf from sheet set dont finish cad 2015
hi
when i plot pdf from sheet set ( plublish to pdf)   the job dont finish cad 2015
steel saying : publish plot in progress  for long time more than an hour ?
thank you
tmccar
Which printer are you using? Can you edit your page setup before running Publish, select the "DWG to PDF" printer and save the page setup.
Then from within Publish, choose "Printer named in page setup" under "publish to".
hi
thank you for your unswer
i already use dwg to pdf , the problem was my be in the mnu or the suppot  file , I dont know.
the solution that I find and it works , I took my colleague profile how his plotting working ( exporte profile )  , and rename it and impot it to my cad  options profile  , and I have adapted to my preferences and the plotting works know
thank you
