Announcements
Plot AutoLISP Problem "Proceed with plot"
wstowe
wstowe
First day of really making a LISP routine. It was exciting that it actually worked!
Except for the very last input.
;11X17_PDF
(defun C:p11 ()
(command "-plot" "n" "" "11x17_pdf" "DWG To PDF.pc3" "n" "YES")
(princ)
I run the routine in autocad, however the command line keeps asking me the last question of "Proceed with Plot". I had "y" originally and changed to "YES"(because I saw that somewhere else online) but still keeps asking me yes or no even though i answered yes in the script.
Any help would be appreciated.
Replies (7)
dlanorh
Try adding "" after "Yes"
I am not one of the robots you're looking for
wstowe
That did it!
What was the problem?
Sea-Haven
The longer winded version may be helpful this is used in plot a range of layouts.
(COMMAND "-PLOT"  "Y"  "" "DWG To PDF"
	       "Iso full bleed A3 (420.00 x 297.00 MM)" "m" "LANDSCAPE"  "N"   "W"  "-6,-6" "807,560" "1=2"  "C"
	       "y" "Acad.ctb" "Y"	"n" "n" "n" pdfName "N" "y"
wstowe
Thanks for sharing! I'm guessing this is for multiple layouts in a single drawing?
All of our drawings are in model space. And some point I will look into making a LISP that will make a PDF of all open drawings.
dlanorh
@wstowe wrote:
That did it!
You weren't finishing the command, it was waiting for the final return ("") to finish.
maratovich
View this
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Sea-Haven
The maratovich answer is the best, in a lisp need a title block around each section to be plotted then can work out the area to plot and what scale to use. I have done it but promote using layouts as the preferred way.
