Please lisp code requaired
iftikhargulmrd
iftikhargulmrd
hey all I want code for chainage marking  lisp instead of interval to ask me for each distance one by one
regards
dbhunia
Try with this.......
(defun c:ChainageMark()
    (setq Pl1Name (car (entsel "\nPick Centerline "))
          MarkLength (getreal "\nEnter Tick Length ")
	  CurrStation 0
          MaxLength (vlax-curve-getDistAtPoint Pl1Name (vlax-curve-getEndPoint Pl1Name))
          currLayer (getvar "CLAYER") ; change as needed
    );setq
    (while (and (setq StaInterval (getreal "\nEnter Chainage Interval "))
		(< (setq CurrStation (+ CurrStation StaInterval)) MaxLength)
          (setq currPoint (vlax-curve-getPointAtDist Pl1Name currStation)
		currParam (vlax-curve-getParamAtDist Pl1Name currStation)
		PerpAng (dkb_getPerp Pl1Name currParam 1)
		Pt1 (polar currPoint PerpAng (* MarkLength 0.5))
		Pt2 (polar currPoint PerpAng (* MarkLength -0.5))
		LineList (list
                          '(0 . "LINE")
                          '(100 . "AcDbEntity")
                          '(100 . "AcDbLine")
                          (cons 8 currLayer)
                          (cons 10 Pt1)
                          (cons 11 Pt2)
			);list
         );setq
         (entmake LineList)
    );while
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
iftikhargulmrd
thanks a lot brother as always you are the first one
iftikhargulmrd
sir
can please check the error in lisp
; error: no function definition: DKB_GETPERP
dbhunia
The message indicates that the function "dkb_getPerp" is not loaded......
You have to load 3 LISP, to run the command.....
Did you loaded all 3 LISP........
Load all ..... then try
Debashis Bhunia
iftikhargulmrd
thanks a lot
yes it was same issue
Best Regards
