Please help me with this code
Is there a solution for getting the classic LISP websec to work in autocad 2016? The code is below. I have tried replacing "command" with "command-s" in accordance with the autolisp help page suggestion, but have not been able to get the below routine to give anything other than a wc internal error, a command-s error, or upon entering an insertion point, a polyline is begun. Thank you for your time looking, and Godspeed.
;;; WEBSEC.lsp
;;; Copyright (C) 1991 by Autodesk, Inc.
;;; Permission to use, copy, modify, and distribute this software and its
;;; documentation for any purpose and without fee is hereby granted.
;;; THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED WARRANTY.
;;; ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR PURPOSE AND OF
;;; MERCHANTABILITY ARE HEREBY DISCLAIMED.
;;; by Carl B. Bethea
;;; 2 June 91
;;; based on a routine
;;; by Tommie Ruble
;;; Drafting Technology Services, Inc.
;;;-- getnum -----------------------------------------------
;;; get a distance, disallow null, 0, or negative
(defun getnum (string)
(initget 7)
(getdist string)
;;;-- draw_pline -------------------------------------------
;;; generic pline engine
(defun draw_pline (/ dxdy)
;; if start point not defined, then get one
;; see tube for why this check is useful
(if (null ip)
(setq IP (getpoint "\nInsertion Point: "))
(command "pline" ip
(mapcar
'(lambda (dxdy)
;; if the entry from the data table is longer than
;; an x-y-z list, then execute the command(s) at the
;; the beginning of the entry,
;; then truncate the entry to x-y-z
(while (> (length DXDY) 3)
(command-s (car DXDY))
(setq DXDY (cdr DXDY))
;; generate a point based on dx dy dz
;; from the last point
(command
(setq IP
(mapcar '(lambda (i j) (+ i (eval j)))
IP
dxdy
data_table
);mapcar
);commnd
);draw_pline
;;;-- w ----------------------------------------------------
;;; draw an W-section
;;; starts at lower left corner, runs clockwise
(defun w (/ d e f h a b)
(setq
D (getnum "\nDepth ==> ")
E (getnum "\nWeb Thickness ==> ")
F (getnum "\nFlange Width ==> ")
H (getnum "\nFlange Thickness ==> ")
(w_draw d e f h)
);w
(defun w_draw (d e f h / a b data_table ip)
(setq
A (- (/ F 2) (/ E 2) H)
B (- D (* 4 H))
;; create a data table which describes the
;; dx, dy, dz values for each point of the section
;; note all arcs are assumed tangent to previous line
data_table
'((0 H 0)
(A 0 0)
("ARC" H H 0)
("LINE" 0 B 0)
("ARC" (- H) H 0)
("LINE" (- A) 0 0)
(0 H 0)
(F 0 0)
(0 (- H) 0)
((- A) 0 0)
("ARC" (- H) (- H) 0)
("LINE" 0 (- B) 0)
("ARC" H (- H) 0)
("LINE" A 0 0)
(0 (- H) 0)
((- F) 0 0)
);end table
);setq
(draw_pline)
);web
;;;-- s ----------------------------------------------------
;;; draw s-section
(defun s (/ d e f h)
(setq
H (getnum "\nAvg Flange Thk ==> ")
(s_draw d e f h)
);s
(defun s_draw (d e f h / a b m i L x y data_table ip)
(setq
A (- (/ F 2) (/ E 2))
M (* 0.15838444 (/ A 2.0))
B (- D (* 2 (+ M H)))
I (atan A (* 2 M)) ; internal angle of arc
L (- H M) ; tangent length of fillet
Y (polar '(0 0 0) (- (/ pi 2) I) L)
X (car Y) ; dx of fillet
Y (cadr Y) ; dy of fillet
data_table
'(("ARC" "DIRECTION" 0 (- H M) 0)
(X Y 0)
("LINE" (- A X) (- (* 2 M) Y) 0)
(0 B 0)
((- X A) (- (* 2 M) Y) 0)
("ARC" "DIRECTION" (- X) Y 0)
(0 L 0)
("LINE" F 0 0)
("ARC" "DIRECTION" 0 (- M H) 0)
((- X) (- Y) 0)
("LINE" (- X A) (- Y (* 2 M)) 0)
(0 (- B) 0)
((- A X) (- Y (* 2 M)) 0)
("ARC" "DIRECTION" X (- Y) 0)
(0 (- L) 0)
("LINE" (- F) 0 0)
);end table
);setq
(draw_pline)
);s
;;;-- channel ----------------------------------------------
;;; draw channel section
(defun channel (/ d e f h)
(setq
(c_draw d e f h)
);channel
(defun c_draw (d e f h / a b m i L x y data_table ip)
(setq
A (- F E)
data_table
'((0 D 0)
(F 0 0)
((- X) (- Y) 0)
(0 (- B) 0)
(0 (- L) 0)
("LINE" (- F) 0 0)
);end table
);setq
(draw_pline)
);channel
;;;-- angled -----------------------------------------------
;;; draw angle section
(defun angled (/ d f h)
(setq
F (getnum "\nHorizontal Length ==> ")
D (getnum "\nVertical Length ==> ")
H (getnum "\nAngle Thickness ==> ")
(a_draw f d h)
);angled
(defun a_draw (f d h / data_table ip)
(setq
data_table
'((0 D 0)
("ARC" "DIRECTION" H 0 0)
(0 (- H) 0)
("LINE" 0 (- (* 2 H) D) 0)
((- F (* 2 H)) 0 0)
("ARC" H (- H) 0)
("LINE" (- F) 0 0)
);end table
);setq
(draw_pline)
);angled
;;;-- tube -------------------------------------------------
;;; draw tube section
(defun tube (/ d f h h2)
(setq
H (getnum "\nWall Thickness ==> ")
(t_draw f d h ip)
);tube
(defun t_draw (f d h ip / h2 data_table)
(setq
H2 (* 2 H)
ip (list (car ip) (+ H2 (cadr ip))(caddr ip))
;; section for the outer tube
data_table
'((0 (- D H2) 0)
("ARC" H2 H2 0)
("LINE" (- F H2) 0 0)
("ARC" H2 (- H2) 0)
("LINE" 0 (- H2 D) 0)
("ARC" (- H2) (- H2) 0)
("LINE" (- H2 F) 0 0)
("ARC" (- H2) H2 0)
);end table
);setq
(draw_pline)
(setq
ip (list (+ H (car ip)) (cadr ip)(caddr ip))
;; inside tube
data_table
'((0 (- D H2) 0)
("ARC" H H 0)
("ARC" H (- H) 0)
("ARC" (- H) H 0)
);end table
);setq
(draw_pline)
);angled
;;;-- err --------------------------------------------------
(defun err (s)
(if (/= s "Function cancelled")
(princ (strcat "\nError: " s))
(setq *error* olderr)
(setvar "cmdecho" cm)
(princ)
;;;-- c:websec ---------------------------------------------
;;; main program to draw beam sections
(defun c:websec (/ option ip cm olderr)
(setq cm (getvar "cmdecho")
olderr *error*
*error* err
(setvar "cmdecho" 0)
(initget "W S Channel Angled Tube ")
(if (null (setq option
(getkword "\nAngled/Channel/S/Tube/<W>: ")
(setq option "W")
(eval (list (read option)))
(princ)
;;;--- end of file -----------------------------------------
