Message 1 of 14
Please help me with lisp
poly line length from start with Curve up to tp-1(+) from tp-1 to IP distace (place as apex at km ?
something quick.
(vl-load-com) (defun c:apex ( / p v) (and (setq p (car (entsel "polyline: "))) (vl-cmdf "_copy" p "" '(0 0) '(0 0)) (setvar 'filletrad 0) (setq p (entlast)) (vl-cmdf "_fillet" "_P" (entlast) "") (setq v (mapcar 'cdr (reverse (cdr (reverse (cdr (vl-remove-if-not '(lambda (x) (= 10 (car x))) (entget p)))))))) (foreach x v (entmakex (list '(0 . "TEXT") (cons 10 x) '(40 . 1) (cons 1 (strcat "APEX AT KM " (rtos (vlax-curve-getdistatpoint p x) 2 3)))))) (entdel p) ) (princ) )
This?
Place MLEADER at vertex and give the length of the tangent for ARC or POLYARC
(vl-load-com)
(defun make_mlead (pt o d / ptlst arr nw_obj)
(setq
ptlst (append pt (polar pt o d))
arr (vlax-make-safearray vlax-vbdouble (cons 0 (- (length ptlst) 1)))
(vlax-safearray-fill arr ptlst)
(setq nw_obj (vla-addMLeader Space (vlax-make-variant arr) 0))
(vla-put-contenttype nw_obj acMTextContent)
(vla-put-textstring nw_obj (strcat "{\\fArial|b0|i0|c0|p34;+" (rtos d 2 3) "}"))
(vla-put-layer nw_obj (getvar "CLAYER"))
(vla-put-ArrowheadSize nw_obj (* (getvar "TEXTSIZE") 0.5))
(vla-put-TextHeight nw_obj (getvar "TEXTSIZE"))
(if (> (car ptlst) (cadddr ptlst))
(progn
(vla-SetDogLegDirection nw_obj 0 (vlax-3D-point '(-1.0 0.0 0.0)))
(vla-put-TextJustify nw_obj acAttachmentPointMiddleRight)
(vla-setLeaderLineVertices nw_obj 0 (vlax-make-variant arr))
(vla-put-TextJustify nw_obj acAttachmentPointMiddleLeft)
(vla-update nw_obj)
(defun c:Lenght_Tangent ( / js n AcDoc Space ename obj pr nb typ_obj oldim oldlay a_base a_dir pt_start pt_end pt_cen rad alpha pt_vtx x dist_start dist_end seg_len seg_bulge)
(princ "\nSelect Arcs/PolyArcs .")
(setq
js
(ssget
'((-4 . "<OR")
(-4 . "<AND")
(0 . "POLYLINE")
(-4 . "<NOT")
(-4 . "&") (70 . 126)
(-4 . "NOT>")
(-4 . "AND>")
(0 . "LWPOLYLINE,ARC")
(-4 . "OR>"))
n -1
(cond
(js
(setq
AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
Space
(if (= 1 (getvar "CVPORT"))
(vla-get-PaperSpace AcDoc)
(vla-get-ModelSpace AcDoc)
nb 0
(cond
((null (tblsearch "LAYER" "Length Tangent"))
(vlax-put (vla-add (vla-get-layers AcDoc) "Length Tangent") 'Color "5")
(setq
oldim (getvar "dimzin")
oldlay (getvar "clayer")
a_base (getvar "ANGBASE")
a_dir (getvar "ANGDIR")
(setvar "dimzin" 0) (setvar "clayer" "Length Tangent")
(setvar "ANGBASE" 0) (setvar "ANGDIR" 0)
(repeat (sslength js)
(setq
ename (ssname js (setq n (1+ n)))
obj (vlax-ename->vla-object ename)
pr -1
nb 0
(setq typ_obj (vla-get-ObjectName obj))
(if (eq typ_obj "AcDbArc")
(progn
(setq
pt_start (vlax-get obj 'StartPoint)
pt_end (vlax-get obj 'EndPoint)
pt_cen (vlax-get obj 'Center)
rad (vlax-get obj 'Radius)
alpha (* (vlax-get obj 'TotalAngle) 0.5)
seg_len (vlax-get obj 'ArcLength)
pt_vtx (polar pt_cen (+ (vlax-get obj 'StartAngle) alpha) (+ rad (* rad (1- (/ 1 (cos alpha))))))
nb (1+ nb)
x (angle pt_cen pt_vtx)
(make_mlead pt_vtx x (distance pt_start pt_vtx))
(repeat (fix (vlax-curve-getEndParam obj))
(setq
dist_start (vlax-curve-GetDistAtParam obj (setq pr (1+ pr)))
dist_end (vlax-curve-GetDistAtParam obj (1+ pr))
pt_start (vlax-curve-GetPointAtParam obj pr)
pt_end (vlax-curve-GetPointAtParam obj (1+ pr))
seg_len (- dist_end dist_start)
seg_bulge (vla-GetBulge obj pr)
(if (not (zerop seg_bulge))
(progn
(setq
rad (/ seg_len (* 4.0 (atan seg_bulge)))
alpha (+ (angle pt_start pt_end) (- (* pi 0.5) (* 2.0 (atan seg_bulge))))
pt_cen (polar pt_start alpha rad)
pt_vtx (polar pt_start (- alpha (* pi 0.5)) (* rad (/ (sin (* 2.0 (atan seg_bulge))) (cos (* 2.0 (atan seg_bulge))))))
alpha (if (< (* 2.0 (atan seg_bulge)) 0) (- pi (* 2.0 (atan seg_bulge))) (* 2.0 (atan seg_bulge)))
nb (1+ nb)
(setvar "dimzin" oldim) (setvar "clayer" oldlay)
(setvar "ANGBASE" a_base) (setvar "ANGDIR" a_dir)
(prin1)
Good diagram. I used to know all those formulas by heart. Don't need to these days.
In the US we call them PIs (Point of Intersection). Then the radius is assigned and we compute the tangent just to get the station (chainage) of the PC. I don't think there's any other purpose.
Back in the day, the survey crew would find the intersection of the two tangents in the field (even if in the woods), then set up there and measure the delta from back to forward. Clearing brush and felling trees were all part of the process. Usually a 3-man or 4-man crew. If they had a slide rule they could lay out the curve in the same or next day.
John F. Uhden
Yeah "If they had a slide rule they could lay out the curve in the same or next day." Now 1 man total station upload alignment enter chainage instrument works out pt.
We just make a setout file and give to surveyor usually a picture as well so gets an idea of where points are even in trees. So why need the request ???
actually i need this
TP1 length = Curve polyline length up to every TP-1 and place text as " TP-1@ ??.??? KM' "
TP2 length = Curve polyline length up to every TP-2 and place text as " TP-2@ ??.??? KM' "
APEX length = (Curve polyline length up to every TP-1 + tangent length and place text as " APEX-? AT ??.??? KM "
FORWARD BARRING = place text as " FB : ???° ??' ?? "
Asking at cadtutor as well answer is not getting to him/her fast enough, dont worry about those paying jobs drop everything and do the free ones.
@Sea-Haven a écrit :Asking at cadtutor as well answer is not getting to him/her fast enough, dont worry about those paying jobs drop everything and do the free ones.
Ah yes I see now!
He does multi-posting, does not respond to proposals, and eternally asks the same question !!!...
Not encouraging to follow his request.
