Place XLINE into the selection set objects
Dear All,
I am trying to put "XLINE" in all the "CENTER" lines. For that i an trying the way of like Selection set > get the starting point and end point then placing the XLINE. Below are my code. But i am facing problrm in that.
Could anybody can solve this and teach me where i put wrongly ?? will be appreciated.
(defun c:xlines()
	(command "FILEDIA" 0)	;;Making command line process
	(setvar "CMDECHO" 0)	;;Turn off the SNAP
	(command "TILEMODE" "1")
		(if (setq cL(ssget '((0 . "LINE")(8 . "Top (Plan) View-CENTER"))))
			(progn
				(setq ctr 0)
				(while
					(setq ent(ssname cL ctr))
					(setq ln(car ent))
					(setq lnEnt(entget ln))
					(setq startPoint(cdr(assoc 10 lnEnt)))
					(setq endPoint(cdr(assoc 11 lnEnt)))
					(if (=(car(cdr(assoc 10 lnEnt))) (car(cadr(assoc 11 lnEnt))))
						(progn
							(command "_.XLINE" "V" startPoint "")
					(command "_.XLINE" "H" startPoint "")
				(setq ctr(1+ ctr))
	(command "TILEMODE" "0")
	(princ)
Regards
Ananth
Accepted solutions (3)
ВeekeeCZ
This is all you need. Not sure if you put TILEMODE setting on purpose - get it back if so.
(defun c:xlines (/ s d i)
  (setvar 'cmdecho 0)
  (if (setq s (ssget '((0 . "LINE") (8 . "Top (Plan) View-CENTER"))))
    (repeat (setq i (sslength s))
      (setq d (entget (ssname s (setq i (1- i)))))
      (command "_.xline" "_non" (cdr (assoc 10 d)) "_non" (cdr (assoc 11 d)) "")))
  (setvar 'cmdecho 1)
  (princ)
ВeekeeCZ
Your code fixed and commented.
Consider using the Reverse Repeat method, see HERE .
(defun c:xlines( / )
  ;; (command "FILEDIA" 0)	don't need this at all.
  (setvar "CMDECHO" 0)	;;Turn off echo
  (if (setq cL (ssget '((0 . "LINE"))));(8 . "Top (Plan) View-CENTER") )))
    (progn
      (setq ctr 0)
      (while                           ;; I would use REVERSED REPEAT method. It's easier and faster.
	(setq ent (ssname cL ctr))
	;(setq ln (car ent))    ; wrong line, car is used when entity comes from entsel... (setq ent (car (entsel)))
	(setq lnEnt (entget ent))
	(if (equal
	     ;=                       = when comparing reals, use equal with fuzzy!!!! reals are not precise enougth, these are not identical
	      (car(cdr(assoc 11 lnEnt)))  ; cadr was wrong
	      0.001)             ; suitable fuzz
	  (command "_.XLINE" "V" startPoint "")  ; some parenthesis were wrong !!
	  (command "_.XLINE" "H" startPoint ""))
      (setq ctr(1+ ctr)))))
  (princ)
hak_vz
(setq ln(car ent))
Elements in selection set are defined different then those created with command entsel. so this is not needed
@ВeekeeCZ  posted this as I was typing this
Miljenko Hatlak
cadffm
Hi
this is not a solution, just comments for learning
(defun c:xlines()
(command "FILEDIA" 0) ;;Making command line process This is for standard file selection dialog an in lisp ALWAYS USELESS, specially in programs like this, without a standard file dialog in process
(setvar "CMDECHO" 0) ;;Turn off the SNAP This has nothing to do with SNAP (and SNAP has nothing to do with what you think about '(you mean OSNAPs, i guess) , CMDECHO is the commandline feedback of commands - what you can see, or not, in [F2]
(progn
(setq ctr 0)
(while
;;(setq ent(ssname cL ctr)) ; feedback is an ename like <Objektname: 2e839e64c0>
;;(setq ln(car ent)) ; car is for extraction the first element of a list, but your 'ent' contains an ename and not a list
(setq lnEnt(entget (ssname cL ctr))) ;< this line is enough, no need for  (setq ent / (setq ln
means
(assoc 11 lnEnt) = (11 0.0 5.0 0.0)
(cadr(11 7.3 5.0 0.0)) = 7.3
(car 7.3) = ; car is for extraction the first element of a list, 7.3 is not a list
(progn
(command "_.XLINE" "V" startPoint "") ; Why _.XLINE and not .XLINE? or better: Why V and not _V ? It's useless to use international commands and options just less then 100% in  code
(command "_.XLINE" "_V" startPoint "")and it works in all language version.
) ; <== This is the closing IF-statement bracket, Xline-H will drawn for every line, is this what you want?
(command "_.XLINE" "H" startPoint "") ; the same as before with V => better: (command "_.XLINE" "_H" startPoint "")
); <== This is the closing While-statement bracket, (setq ctr is outside of while and it runs in a never ending loop
(setq ctr(1+ ctr))
(command "TILEMODE" "0") ; better is to save the current setting at start and set it back at the end
(princ)
Sebastian
This code is awesome and more simple than mine, i have learnt a new today.
Thanks you for your correct code and your suggestion.
