pickset manipulating
vishshreevT578L
Message 1 of 13
vishshreevT578L
I want to manipulate this pickset,
I mean i want to make separate list of all the text, line, Mtext, polyline.
can anyone please suggest
Shreev
Accepted solutions (3)
Replies (12)
Message 2 of 13
ВeekeeCZ
Try this sub...
(defun :ssByType (ss / typlst i a en typ)
  (repeat (setq i (sslength ss))
    (setq en (ssname ss (setq i (1- i)))
          typlst (if (setq a (assoc (setq typ (cdr (assoc 0 (entget en)))) typlst))
                   (subst (cons typ (ssadd en (cdr a))) a typlst)
                   (cons (cons typ (ssadd en)) typlst)))))
Sometimes could be useful some quick a simple way to filter...
#2
(ssget ss)
(setq ssline (ssget "_P" '((0 . "LINE"))))
(sssetfirst nil ss) ; ss must be highlighted again
(setq sscircle (ssget "_P" '((0 . "CIRCLE"))))
#3
(setq ssline (acet-ss-ssget-filter ss '((0 . "LINE"))))
(setq sscircle (acet-ss-ssget-filter ss '((0 . "CIRCLE"))))
Message 3 of 13
Kent1Cooper
If 'pickset' is a variable containing [as the name implies] a selection set, and you mean you want to make separate selection sets of the different entity types in it, try this:
(sssetfirst nil pickset); selects/grips/highlights everything in it; then:
(setq TextFromPickset (ssget '((0 . "TEXT")))); puts all Text objects from current active selection into a variable
(sssetfirst nil pickset); do it again, then:
(setq LinesFromPickset (ssget '((0 . "LINE")))); puts all Line objects into a variable
.... etc. for other types
If you really want to make lists of them all, there are a couple of ways you could do that.  One is to make the separate selection sets as above, and then code could be added to make a list from each of those.  Another is to step through the pickset variable's selection set, and put each item into a list corresponding to its entity type [EDIT: for example, @ВeekeeCZ's first suggested subroutine].  Is something like one of those what you really need?
Kent Cooper, AIA
Message 4 of 13
vishshreevT578L
Thanks sir
Can i do this using vlisp
Shreev
Message 5 of 13
Ranjit_Singh
or you can use mapcar to go through each entity and add to separate sets
(setq ssline (ssadd) sstext (ssadd) sslwp (ssadd))
(mapcar '(lambda (x)
	(cond 	((and (= (car x) 3) (= (cdr (assoc 0 (entget (cadr x)))) "LINE")) (ssadd (cadr x) ssline))
		((and (= (car x) 3) (= (cdr (assoc 0 (entget (cadr x)))) "TEXT")) (ssadd (cadr x) sstext))
		((and (= (car x) 3) (= (cdr (assoc 0 (entget (cadr x)))) "LWPOLYLINE")) (ssadd (cadr x) sslwp))
		(T ())
)) (ssnamex ss1))
Message 6 of 13
vishshreevT578L
SORRY...FOR THE WRONG QUESTION POSTED.
SIR....
I MEANT HERE TO SAY THAT I DON`T WANT TO GO FOR SELECTION SET EACH AND EVERY TIME.
FROM THIS SSSET ITSELF I WANT TO LIST ALL ENTITIES SEPARATELY...NOW I WANT TO MAKE IT NIL AND AGAIN GO FOR NEW SELECTION SET.
Shreev
Message 7 of 13
ВeekeeCZ
SIR....
Then try this.... (hope I understood this time)
(defun :lstByType (ss / typlst i a en typ)
                   (subst (cons typ (cons en (cdr a))) a typlst)
                   (cons (cons typ (list en)) typlst)))))
(defun c:test ()
  (assoc "LINE" (:lstByType (ssget)))
Message 8 of 13
vishshreevT578L
(SETQ SSET (SSGET)) ;NOW I HAVE A SELECTION SET OF ALL ENTITIES AS THE IMAGE ATTACHED ABOVE
NOW FROM THIS SELECTION SET (SSET) I HAVE TO MAKE A LIST OF RESPECTIVE ENTITIES.....
LIKE I CAN DO AS BELOW
(SETQ SSTEXT (SSGET "_P" '((0 . "TEXT")))) ; ALL TEXT ARE STORED TO VARIABLE SSTEXT
BUT AGAIN AFTER THIS I HAVE TO MAKE MY SELECTION SET NIL THEN GET A SELECTION SET, I WANT TO WRITE ONE CONDITION FROM WHICH ALL SIMILAR ENITIES ARE STORED TO THERE RESPECTIVE VARIABLE..
SORRY AND HOPE MY QUESTION IS CORRECT NOW..
Shreev
Message 9 of 13
SeeMSixty7
Try this. this will create a "ENTTYP"-ss for you based on the Enttypes in the list below.
If you run this in your drawing, you will end up with 3 variables that have selections sets.
LINE-SS
TEXT-SS
LWPOLYLINE-SS
If any of these entity types exist in your drawing there will be something in the selection set for that entity type. If you want different entity types simply add them to the entTypes list.
Good luck
(defun GetSSBreakout()
 (setq Overallss (ssget "X")
    entTypes (list "LINE" "TEXT" "LWPOLYLINE")
 (if Overallss
  (progn
   (foreach enttype entTypes
    (set (read (strcat enttype "-ss")) (ssadd))
   (setq OverallNum (sslength Overallss)
      overallcnt 0
   (while (< overallcnt overallnum)
    (setq ent (ssname overallss overallcnt)
       data (entget ent)
       enttyp (cdr (assoc 0 data))
       overallcnt (1+ overallcnt)
    (if (member enttype enttypes)
     (set (read (strcat enttype "-ss")) (ssadd (cdr (assoc -1 data))))
Message 10 of 13
ВeekeeCZ
(SETQ SSET (SSGET))
BUT AGAIN AFTER THIS I HAVE TO MAKE MY SELECTION SET NIL THEN GET A SELECTION SET...
As me and Kent said before, you don't need to select your entities again manually using simple (ssget), just use (sssetfirst nil SSET), then you can use the Previous parameter of (ssget) function again... (ssget "_P" '((0 . "ANYTYPE")))
(SETQ SSET (SSGET))
(SETQ SSLINE (SSGET "_P" '((0 . "LINE"))))
(SETQ SSMTEXT (SSGET "_P" '((0 . "MTEXT"))))
... using (acet-ss-ssget-filter) you don't need to use (sssetfisrt...)
(SETQ SSET (SSGET))
(setq sstext (acet-ss-ssget-filter SSET '((0 . "TEXT"))))
(setq ssline (acet-ss-ssget-filter SSET '((0 . "LINE"))))
(setq sscircle (acet-ss-ssget-filter SSET '((0 . "CIRCLE"))))
HTH
Message 11 of 13
Kent1Cooper
(SETQ SSET (SSGET))
With the set selected/gripped/highlighted by (sssetfirst), you don't need the "_P" part [see Post 3]:
(sssetfirst nil (SETQ SSET (SSGET)))
(SETQ SSTEXT (SSGET '((0 . "TEXT"))))
(SETQ SSLINE (SSGET '((0 . "LINE"))))
(SETQ SSMTEXT (SSGET '((0 . "MTEXT"))))
Kent Cooper, AIA
Message 12 of 13
vishshreevT578L
(DEFUN PL:GET-TBL-ENTS ( / CORN1 CORN2 )
(SETQ CORN1 (GETPOINT "\nSelect ll corner of table : "))
(SETQ CORN2 (GETCORNER CORN1 "\nSelect ur corner of table : "))
(LIST
(SSGET "_C" CORN1 CORN2 '((0 . "LINE")))
(SSGET "_C" CORN1 CORN2 '((0 . "LWPOLYLINE")))
(SSGET "_C" CORN1 CORN2 '((0 . "TEXT")))
(SETQ SEL (PL:GET-TBL-ENTS))
Hello Sir,
In the above code i get a list of a selection set by "getpoint method" i
want the same result using just ssget function.
I tried to do by the method you suggested of about sssetfirst Nil but i am
not getting what i want please solve my querry
Please solve my querry
Shreev
Shreev
Message 13 of 13
Kent1Cooper
not getting what i want please solve my querry....
Since it is necessary, in the (sssetfirst nil) approach, to run that (sssetfirst) function prior to each entity-type-filtered (ssget) function, so that it has a pre-selection to pick from and will not ask the User to select things each time, I believe it is therefore also necessary to build the list of selection sets one at a time with the (sssetfirst) functions between the entity-type selections, rather than have the (ssget) functions grouped within a (list) function.  Try this [lightly tested]:
(defun SSLIST (/ sset)
  (sssetfirst nil (setq sset (ssget)))
  (setq sslist (list (ssget '((0 . "TEXT"))))); start the list
  (setq sslist (cons (ssget '((0 . "LWPOLYLINE"))) sslist)); add to it
  (setq sslist (cons (ssget '((0 . "LINE"))) sslist)); add to it
); defun
Usage:  (SSLIST) [in parentheses, as your example was defined -- could instead be (defun C:SSLIST ...) to use a command name without the parentheses].
Kent Cooper, AIA
