Picking a block to save it's name for later in a routine
I know this is a simple thing to do, but I'm a hack, so I'm putting it out there:
I want to be able to select a block in a drawing and set it's name as a setq value, so I can use that name later in the same routine in an "insert" string.
What's the best way to achieve this??
Thanks.
Kent1Cooper
This should cover either an ordinary or a dynamic Block:
(setq blkname
  (vla-get-effectivename
    (vlax-ename->vla-object (car (entsel "\nSelect Block: ")))
If they will never be dynamic  Blocks, it can be slightly simpler:
(setq blkname (cdr (assoc 2 (entget (car (entsel "\nSelect Block: "))))))
Kent Cooper, AIA
Thanks Kent! Greatly appreciated!
Doug
