Pick attribute from block and polyline handle and paste in other block
RBernaz
Message 1 of 11
RBernaz
As I don't understand a word of lisp programming, I would like to ask someone who understand to please help me. I thank you in advance.
I would like same lisp routine to pick  a attribute "A" from a block "X" to paste to an attribute "A" in a block "Y" and in a second step pick a polyline handle and past it in attribute "H" in the same block "Y".
Hope I'm explaining well, is that possible or easy to make?
Many thanks
Replies (10)
Message 2 of 11
dlanorh
Are "A" &  "H" the Attribute Tags or do you want to select attribute (get value) select attribute (put value) Select polyline (get handle) select attribute (put handle) as the value?
I am not one of the robots you're looking for
Message 3 of 11
RBernaz
Hi dlanorh ,
Thank you very much for your reply,
I think in either cases I want to copy paste the values found within same Tag names and the handle the same
I hope I'm being clear enough
Regards
Message 4 of 11
dlanorh
What is the tag name of the attribute to contain the handle?
Message 5 of 11
RBernaz
HANDLE_LANCO
Message 6 of 11
dlanorh
Try this. Select attribute to copy, select Pline and select block. Not tested as currently on a LT version.
(vl-load-com)
(defun c:a2a ( / *error* c_doc sv_lst sv_vals aobj tn tv ph bobj)
  (defun *error* ( msg )
    (mapcar 'setvar sv_lst sv_vals)
    (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error : " msg " occurred")))
    (princ)
  );end_defun
  (setq c_doc (vla-get-activedocument (vlax-get-acad-object))
        sv_lst (list 'cmdecho 'osmode)
        sv_vals (mapcar 'getvar sv_lst)
  );end_setq
  (mapcar 'setvar sv_lst '(0 0))
  (setq aobj (vlax-ename->vla-object (car (nentsel "\nPick Block Attribute to copy  : ")))
        tn (vlax-get aobj 'tagstring)
        tv (vlax-get aobj 'textstring)
        ph (cdr (assoc 5 (entget (car (entsel "|nSelect Polyline for Handle : ")))))
        bobj (vlax-ename->vla-object (car (entsel "\nSelect Destination Block : ")))
  );end_setq
  (foreach att (vlax-invoke bobj 'getattributes)
    (cond ( (= (strcase tn) (strcase (vlax-get att 'tagstring))) (vlax-put att 'textstring tv))
          ( (= "HANDLE_LANCO" (strcase (vlax-get att 'tagstring))) (vlax-put att 'textstring ph))
    );end_cond
  );end_foreach
  (vla-regen c_doc acallviewports)
  (princ)
);end_defun
Message 7 of 11
RBernaz
FANTASTIC, many many thanks
it works very well, is exactly what I was looking for
thank you
best regards
Message 8 of 11
dlanorh
@RBernaz
Glad it was useful.
I have updated the code above as I had missed the regen, which is always a good idea when working with attributes
If you need it to loop let me know.
Message 9 of 11
Sea-Haven
Hi Dlanorh I use nentsel to get attribute tag makes the routines more global, it also returns the attribute value. You can also use pick point to get block name if required. So many times the request is changed regarding tag names.
Message 10 of 11
RBernaz
Hi, sorry for asking another request....
Could you please make a simple lisp, just to pick a polyline handle and paste it to a block with attribute "HANDLE_LANCO", just a simple copy paste like.
Thanks, I would much appreciate your attention
Message 11 of 11
ВeekeeCZ
More generic function. You can pick an attribute or polyline as a source.
Also, destination att is identified by a pick, not by name.
(defun c:HTA (/ e d h)
  (and (setq e (car (nentsel "\nGet handle from: ")))
       (setq d (entget e))
       (setq h (cdr (assoc (if (= "ATTRIB" (cdr (assoc 0 d))) 1 5) d)))
       (setq e (car (nentsel "\nPut handle to: ")))
       (setq d (entget e))
       (setpropertyvalue (cdr (assoc 330 d)) (cdr (assoc 2 d)) h)
  (princ)
