Paste Special
Paste Special
Message 1 of 11
Paste Special
Has anyone go a lisp for bring in unformatted text from a Microsoft Office application?
My current procedure is as follows:
In the office document, highlight the text to copy, click copy
In AutoCAD 'Pastespec'
Press the 'T' ket (for paste as Text)
(The text now comes in as an MTEXT object)
Click 'Explode' to reduce the entity to plain text
The Action Recorder doesn't work in this instance only remembering Pastespec
My code below only gets as far as the Paste Special dialogue box & no further
(defun C:PSTSP()
(command "PASTESPEC" "T" "T" )
(command "EXPLODE" "")
(princ)
Replies (10)
Message 2 of 11
hmsilva
Hi sbanister,
the 'Pastespec' command don't have a command line version...
Perhaps something like this will do the trick (untested)...
(defun c:demo (/ _GetClipBoardText pt str)
  (defun _GetClipBoardText (/ htmlfile result)
    ;;  Attribution: Reformatted version of
    ;;  post by Patrick_35 at theswamp.org.
    ;;  See http://tinyurl.com/2ngf4r.
    (setq result
           (vlax-invoke
             (vlax-get
               (vlax-get
                 (setq htmlfile (vlax-create-object "htmlfile"))
                 'ParentWindow
               'ClipBoardData
             'GetData
             "Text"
    (vlax-release-object htmlfile)
    result
  (if (and (setq str (_GETCLIPBOARDTEXT))
           (setq pt (getpoint "\nSpecify text start point: "))
    (entmake
      (list
        (cons 0 "TEXT")
        (cons 100 "AcDbText")
        (cons 10 pt)
        (cons 40 (getvar "TEXTSIZE"))
        (cons 1 str)
  (princ)
Hope this helps,
Henrique
Message 3 of 11
Hello again hmsilva
It does paste as text, however if more than 1 line of the Office application is copied (i.e. several rows from a table in Word or Excel) it pastes as one long
string instead of separate rows
Result:
Desired Result:
Message 4 of 11
hmsilva
Hi sbanister,
I don't have Office in this old laptop, so, again untested...
(defun c:demo (/ _GetClipBoardText ent_last last_ent pt str)
    (setq result
           (vlax-invoke
             (vlax-get
               (vlax-get
                 'ParentWindow
               'ClipBoardData
             'GetData
             "Text"
    result
  (if (not (setq ent_last (entlast)))
    (progn
      (entmake '(
                 (0 . "POINT")
                 (100 . "AcDbEntity")
                 (100 . "AcDbPoint")
                 (10 . (0.0 0.0 0.0))
            last_ent ent_last
    (progn
      (entmake (list
                 '(0 . "MTEXT")
                 '(100 . "AcDbEntity")
                 '(100 . "AcDbMText")
                 (cons 10 pt)
                 (cons 1 str)
      (command "_.explode" "_L")
  (if last_ent
    (entdel last_ent)
  (princ)
Hope this helps,
Henrique
Message 5 of 11
Excellent! It works exacty as I anticipated
10/10
Message 6 of 11
hmsilva
10/10
sbanister,
glad I could help!
Henrique
Message 7 of 11
Jonathan3891
Could this be edited to paste a link?
Jonathan Norton
Blog | Linkedin
Message 8 of 11
hmsilva
Hi DSM_dude,
do you mean, attach a 'hyperlink' to an object, using the '_GetClipBoardText' function?
Henrique
Message 9 of 11
Jonathan3891
No, not hyperlinks.
When the paste special dialog box is open, it gives you two radio buttons on the left. One of them is paste link.
I'm looking for a lisp that will select paste link then autocad entity. I thought maybe your lisp could be edited to do so.
Jonathan Norton
Blog | Linkedin
Message 10 of 11
hmsilva
No, not hyperlinks.
No, the previous code just read text strings from clipboard...
Paste link... I've never wrote any code using 'paste link', not even know if it will be possible using AUTO/Visual LISP, but, I'll see what I can do.
Henrique
Message 11 of 11
m_badran
I'm waiting for this
