Paste coordinates in display by macro
I want to put the coordinates on display on a point with text. Because its a lot of coordinates so i want o do it with macro. Does anyone know the command to fix this?
ВeekeeCZ
Welcome to the comunity!
Try the code bellow.
(defun c:coo ( / pnt)
  (while (setq pnt (getpoint "\nPick a point: "))
    (princ (strcat "\nx=" (rtos (car pnt) 2 2)
		   "\ny=" (rtos (cadr pnt) 2 2)
		   "\nz=" (rtos (last pnt) 2 2)))
    (entmakex (list (cons 0 "MTEXT")
		    (cons 100 "AcDbEntity")
                    (cons 100 "AcDbMText")
                    (cons 10 pnt)
                    (cons 1 (strcat "x=" (rtos (car pnt) 2 2) "\\P"
				    "y=" (rtos (cadr pnt) 2 2) "\\P"
				    "z=" (rtos (last pnt) 2 2))))))
  (princ)
Next time you might post a dwg example to see how you imagine the solution.
Kent1Cooper
Since the maximum number of coordinates a point can have is three, and three doesn't sound like "a lot" of coordinates, I assume you mean a lot of points at which you want to put text of their coordinates.  From that, I assume you are talking about Point entities, not mere locations.  Is that correct?
Kent Cooper, AIA
I am a surveyor and i am an amateur when it comes to auto-cad and i want to show coordinates point  i´ve marked yellow on the picture i sent. And i want to show the coordinates on the picture. I hope that picture show what i am trying to do.
ВeekeeCZ
Following code is a LISP. Since you're a student, I'm presuming you know how to google to get to know how to use a LISP.
Routine workflow:
- select a multileader containing a number. Routine will take the number and the coordinates of the head of mleader (the arrow)
- then you pick 2 points to place new mleader on the photo.
- routine take current mleader style - so it's up to you to set correct settings.
(defun c:COO ( / ent pnt txt num)
  (while (and (setq ent (car (entsel "\nSelect mleader containing number <done>: ")))
	      (= (cdr (assoc 0 (entget ent))) "MULTILEADER")
    (setq pnt (cdr (assoc 110 (entget ent)))
	  num (cdr (assoc 304 (entget ent)))
	  txt (strcat "(" num ")"
    (command "_.MLEADER" PAUSE PAUSE txt))
  (princ)
And Student, learn to program!! Unless you have the money to pay for it.
john.uhden
It looks like he/she wants to label the photo.  Don't we need to know its UCS data?
John F. Uhden
