Passing Values to Entmake ATTDEF
mgorecki
mgorecki
I'm just not sure what's going on with this and I hope a second set of eyes will help.
I have some code that's supposed to create a block that contains an attribute.
This is my code, but it's not working.  I think it fails at "(cons 2 tagName)".
I'm not sure if it's because of the combination of hard code and the variables.  If so, how do you use both methods in the same entmake?
(setq blockName "Test1"
insPt '(0.0 0.0 0.0)
tagName "TAG_NAME"
vis 0
justifyHor 0)
(entmake (list (cons 0 "BLOCK") (cons 2 blockName) (cons 10 '(0.0 0.0 0.0)) (cons 70 2) ) ) (entmake (list '(0 . "ATTDEF") '(1 . "") (cons 2 tagName) '(3 . "Enter Value") '(7 . "RomanS") '(8 . "DIM_1") (cons 10 insPt) (cons 11 insPt) '(40 . 2.20) (cons 71 vis) ;0=visible, 1=invisible (cons 72 justifyHor) ;0=Left, 1=Center, 2=Right '(74 . 2) ;2=Middle ) ) (entmake (list (cons 0 "ENDBLK") (cons 8 "0") ) )
Mark
cadffm
Create an attdef by hand with TAG,PROMPT and VALUE,
check the properties by (entget(car(entsel))) and you will see: gc2 is the TAG, gc3 is the PROMPT, gc1 is the predefined value.
Or read the Help about ATTDEF (DXF)
HTH
Sebastian
dlanorh
tagName "TAG_NAME"
vis 0
justifyHor 0)
Mark
(cons 0 "BLOCK")
should be
(cons 0 "INSERT") or '(0 . "INSERT")
I am not one of the robots you're looking for
cadffm
@dlanorh  schrieb:
(cons 0 "BLOCK")
should be
Why? we try to create a block with an attdef, not a insert - it's late, i now 😄
@mgorecki
1. i totally missunderstood the topic/the issue.
2. i oversaw the dxf code 1 in your code
-- it is late -- sorry
Answer: Acad misses the dxf70
 (entmake
  (list
   '(0 . "ATTDEF")
   '(1 . "")
   (cons 2 tagName)
   '(7 . "RomanS")
   '(8 . "DIM_1")
   (cons 10 insPt)
   (cons 11 insPt)
   '(40 . 2.20)
   '(70 . 0) ; http://help.autodesk.com/view/ACD/2020/ENU/?guid=GUID-F0EA099B-6F88-4BCC-BEC7-247BA64838A4
   '(74 . 2) ;2=Middle
Sebastian
mgorecki
Hello CADffm,
I added the '(70 . 0) but unfortunately it still didn't work.  Then the crazy thing; I re-formatted the way I wrote it (based on another program I had written):
		(cons 2 blockName)
		(cons 70 2)
 (entmake (list (cons 0 "ATTDEF")
                (cons 1 "")
                (cons 2 tagName)
                (cons 3 "Enter Value")
                (cons 8 "DIM_1")
                (cons 11 '(0.0 0.0 0.0))
                (cons 70 0) ;Attribute flags, 1 = Attribute is invisible
                (cons 72 1) ;Horizontal text justification, 1 = Center
                (cons 74 2) ;Vertical text justification, 2 = Middle
                (cons 40 2.20)
		(cons 8 "0")
That works just fine. I don't know why that would when the other didn't, but hey I'll take it. 🙂
Best regards,
Mark
cadffm
It works with "I added the '(70 . 0) ", there was another temporary problem in this second of your try.
One hint: You should use the original group code order so long it is easy possible for you - like in this case here!
Because often the order is not important, but often means too: Sometimes the groupcode order is important.
Sebastian
